Plumbing Logo
A
Anonymous Posted on Oct 07, 2014
How do remove a sprayer from a delta model 10901lf faucet
KATHRYN SMITH
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 92 Answers
  • Posted on Feb 03, 2015
KATHRYN SMITH
Expert
Level 2:
New Friend:
Cheetah:
Answers
92
Questions
Helped
36182
Points
207
LOOK FOR A SET BOLT UNDER THE SPRAYER TAKE IT OUT TAKE SPRAYER OFF TO REPLACE
5 Related Answers
arealplumber
Better Plumbing
  • 33 Answers
  • Posted on Dec 05, 2008
SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
arealplumber
Better Plumbing
  • 33 Answers
  • Posted on Dec 09, 2008
SOURCE: Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Donni Steen
  • 687 Answers
  • Posted on Apr 06, 2009
SOURCE: Adjusting single leaver faucet handle
The little wrench tightens the tension ring that fits on the inside of the retaining nut right under the handle. You fit the little "arms" in the notches.
bwbconstruct
  • 23 Answers
  • Posted on Jul 20, 2009
SOURCE: moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Dan Damron
  • 39 Answers
  • Posted on Aug 04, 2009
SOURCE: kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
How do I connect the sprayer hose on single sprayer faucet ,peerless style, the pin wont go in?
What is the model number of the faucet? There was no attached pictures to this submission.
Delta 470 trying to remove metal pull out spray wand but it gets stuck when trying to remove and replace
Are you trying to just replace the sprayer? I replaced the whole unit so cannot help with just the sprayer.
2helpful
My delta signature faucet is leaking from the top of the hose. I want to take the hose out to get a replacement. I have started to disassemble the faucet but don't know how to remove the cap.
i am not sure which cap you refer to. there is a cap just below the handle. turn off the water supply for safety and remove handle then turn the cap counter clockwise. to replace the hose you should only have to disconnect at the handle to the sprayer and the other end at the faucet below the sink. if you wish to remove the faucet then after shutting off the water undo the nut below holding the faucet in place. delta have a good web site where you can see a breakdown of this faucet.
1helpful
Delta side spray replacement
Delta makes sprayers to match the faucet design. Functionally they're about all the same. GO to theirr web site: http://www.deltafaucet.com/customersupport/index.html
If you don't know your model number you can use their wizzard and identify your faucet model. Then go to the parts section. One difference on the number you listed is I believe on comes with the mounting fitting that attaches to the sink. Some don't have it if they go through the faucet base itself.
Delta faucets have lifetime guarantee, I'm not sure if that includes the sprayer. (I doubt it)
I have an older delta faucet. Sprayer does not work well.
i believe the faucet shaft,..they usually are on delta models i've worked on,........your best to get a full rebuild kit for this and do the whole thing when you've got it down,.....good luck, cracklin joe
I have a faucet/sprayer combo and the hose came off when I was using it and now I can't seem to thread it back up....what do I use/do? p.s. I don't know what brand or model...just had to pick something so...
Disconnect hose from sprayer unscrew nut on sprayer head remove washers and you will see a small c shaped clip get that apart then remove hose and thread it back on under sink and feed it back up through sink and reconnect to sprayer
1helpful
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
2helpful
Sprayer loosing presure
  2. Remove handle.
  3. Remove top cap.
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
2helpful
  2. Remove handle.
  3. Remove top cap.
Top Delta Plumbing Experts
john h
vince
Paul Carew
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
