"top of the gas tank where the gas tube fits into the tank"
I assume you're describing the gas tank cap. if so, the o-ring is missing from the gas tank cap. You can find those at hardware stores.
SOURCE: on weedeater blower and vac gas line is broke from
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
SOURCE: craftsman gas blower model #358.797130. replaced
Probably a couple of screws that you took out to access the carb from inside the air filter housing. Probably Torx head screws. You line up the carb and put the air filter housing back on over the carb, lining up the holes in the engine block.
Does this look like the answer you were seeking? Or did I mis-understand?
Testimonial: "Thank you for your quick response. We will try your suggestion."
SOURCE: Homelite 26 BV Gas Leaf Blower
sounds like you had fuel leak into the cylinder over the winter. The liquid in the cylinder is what made it so hard to pull that first time, as it won't compress like air. What you do, is take the spark plug out, pull the starting rope several times, dry off the spark plug, and let both sit(plug out of the cylinder.) for a couple of hours. Then put the plug back in, put the wire back on it, put it on full choke, and pull until it hits once. Then put it on half choke, and pull til it starts.
Testimonial: "Thank you so much FlyingLabRat! That makes perfect sense. I will try it this weekend when I am back home. Much appreciated! "
