2 stroke engine pull start string turns back tire when i try to start it
SOURCE: pulling string on weed eater does not want to turn
It's possible that the engine has seized if the pull cord won't turn the engine over. Remove the starter mechanism from the engine and try to turn the flywheel by hand. One or more of the mounting screws may be hidden under a decal or other label. If the engine won't turn at all, remove the muffler and check the piston skirt for bad scoring--which usually means either dirt inhalation (bad air cleaner) or running the unit on straight gasoline. Either of these conditions require replacement of the cylinder, piston and ring(s) plus labor if you farm out the repair. Weigh the approximate cost of up to $150 against a new trimmer. Hope this helps!
