I am looking for the codes to program the remote to the unit. I cannot seem to find them in the online instruction booklet. Would you happen to know about this?
SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
SOURCE: Sylvania SSD803 DVD Player / VCR Combo
Hi There, You are having a connection problem. Are you using a Yellow red and white cable? Can you provide details your connection from the back of your DVD player and Television. Thanks, Mike
SOURCE: Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo. I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books. So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked. This was a $6.00 universal remote named "One For All" we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on
Pushed the "VCR" button and light blinked once
Pushed and held the "set" button until it blinked twice
Released the "set" button and entered the numbers "0000"
Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
SOURCE: Sylvania LD320SS8 HDTV Can not program COMCAST Remote Control.
try the various codes listed for phillips. that should cure your problem. if not try sampo.
