Need reset code or master code
SOURCE: is there a master unlock code for the Samsung
hi ,
there is no master unlock code for your phone but you can fix it by resetting...here is how ,just follow the procedure...
1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and
reinsert it
2. Hold the Volume Down button
3. Press and release the Power button
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage,
and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button
7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If the above procedures doesn't work, use this second method below,
1. Shut Down Samsung I9000 Galaxy S
2. Now press the Volume up, Home and Power button together.
3. When Samsung Symbol shows up release the power.
4. Then there is a boot Menu. Use the volume up/down to choose and home to select.
If YES is selected, all data including third-party applications will be deleted from your
Samsung I9000 Galaxy S. Once the wipe is complete, the phone will reboot to its factory
fresh state.
i hope it will help you ,thanks for trusting fixya..
SOURCE: Need to reset samsung galaxy s2 phone. Can't
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode"
If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
