Headphone jack seemingly screwed up
What generally happens to connectors, especially exposed to air is they oxydize.
Buy a can of "Contact Cleaner" from a local Radio Shack and spray it (through the thin tube usually provided) into the jack. One quick push, dont flood it. Take the earphone jack and insert and remove it several times, wiping off excess, which sould clear contacts and it should work normally again. If not it would have to be replaced which is no easy matter requiring an experienced Technician or Factory. Sometimes it cannot be replaced without damaging the Mother Board. This however sounds like a common problem the Contact Cleaner will fox
Cheers,
Good Luck :)
Worked fine four three years. Replacing battery did not help.
