Headlights failure.
If the yellow symbol appear as soon as you turn on the dashboard, stop's light bulbs may be the problem.
If the yellow symbol appear when you switch-on lights, the problem may comes from the position's light bulbs.
Ensure that all of the light bulbs are fully working.
Hi, you need to check your audio device driver is installed or not. Go to desktop ,right click and select manage. Now click on device manager and check for yellow symbol on Sound,video and game controller . If you have yellow symbol on it then you need to install audio driver for your PC.
First uninstall the driver.Shut down and restart.If this dont work, shut down and remove the modem.reseat it and restart the PC.If this dont work go to device manager and look for any yellow symbol on the modem properties.If any right click on it and select update driver.
Hello Pankai, hi check cable connections, the speakers connection is on the green port of your speakers. if its fine. Now check if the sound card was detected by your computer, check device manager and see if your sound card is present ( no yellow ! and ?). If you find a yellow symbol on your sound card, needs the device driver, (locate your CD driver) install the device driver for your sound card. if you cannot find the driver CD, visit the manufacturer's website and download the driver. if your sound card is part of the mother board, visit the motherboard's website and find your driver there. you need the motherboard model.
Make sure the network card drivers or modem drivers are installed. go to control panel > system > hardware > device manager. In there any items with a yellow symbol next to them are't working. Right click > update driver.
If it is yellow and looks like a tire it is the flat tire light, and you should check his tire pressure. if it is a yellow triangle with an arrow going around the triangle with a exclamation point in the middle this is your DSC or ASC and if it is on all the time these features are inactive and you should hit the DSC/ASC toggle switch to the right of the drivers window switch. If this symbol just flashes briefly this means the DSC/ASC is presently activating. thest are the tow that I can think of, I hope this helps.
check to see if it's a driver issue:
check in device manager for a ? or a ! next to the pointing device: go start>right click my computer>properties>hardware tab>device manager and look for a yellow symbol with a ! triangle or a yellow "?"sign... if you find this under ponting device you have most likely a driver issue,
check the manufacturer's website for an updated driver for you pointing device and reinstal the driver.
go to start menu , right click on my computer and then click properties, then go to hardware , then click device manager , now a list of devices will come up, if you see anything in yellow there with the ! symbol , that means the drivers are not installed , im guessing this is your problem , you will need to find the drivers for the yellow symbol's
