How do i connect the KP-51WS510 51" projection t.v. to a SONY AVP 800P receiver so that the television will play thru the surround system ?
SOURCE: triple picture and purple bubble on big screen
You may have to degauss your CRTs. Somehow your CRTs have become magnetized and that is what is causing the purple bubble, now as far as the three color pictures, that might be a sign of a convergence problem. for that you may have to put your set into service mode and set the convergence. But first try to degauss the CRTs with a degaussing coil (they have specials on ebay). You will need your owners manual, the remote control, and some patience.
SOURCE: Sony KP-57WS500 57 in. Rear Projection Television
Hi Guys
Your problem here has to do with the amount of aging that happens to the three colour tubes - red, green and blue.
Blue actually ages slower than red and green. What actually happens is the green tube deteriorates and due to green being the predominant colour for brightness causes the blue tube`s flyback lines to appear - especially when switching between inputs or when the video is blanked.
No replacing the blue tube will not solve your problem as the tube is actually the best one of the three.
As someone mentioned there is a way to adjust this by removing the speaker grill assembly in front of the set. Doing the service mode adjustment with the remote is not the right way to solve the problem - you would be adjusting the colour gain and off-set values and would seriously be compromising the white balance of the set.
On the left hand side behind the speaker cover you will see a black square block with six adjustment points. Look for the one marked SCR BLUE, Switch the set to a unused input so the blue lines become visible. Now adjust the BLUE point counter clockwise until the lines disappear. A small adjustment should do it, Switch back to a picture and make sure the whites are still white.
This should sort your problem. I would however suggest asking a Sony service centre to do this for you. This is a dangerous thing to do as you will be working close to the 35Kv supply the the anodes of the three tubes.
I hope this answers your question.
Goo luck.
SOURCE: Sony KP-61HS10 61 in. Rear Projection Television
my tv has the same problem but it blinks five time with no picture but good sound
SOURCE: Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
