Model GLEF379DCB
Before going through with all the above, make sure temp probe is clean (crud all over it is not a good thing). If it does try cleaning it with maybe a spray oven cleaner, Do Not Do This With Oven On, UNPUG!
I’m happy to help further over the phone at https://www.6ya.com/expert/pat_7f6b46a4565f904d
Hey friend, I appreciate your post!
It sounds like your Frigidaire oven could need to be calibrated. If could also be an issue with you thermostat or control panel. In order to properly calibrate your oven you would need to seek assistance from a professional. I would also recommend seeking assistance from a professional for proper diagnosis to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
SOURCE: maytag mgr5870 not baking correctly
hi there,
sounds like the TOD may be at fault. can you supply me with the model # on your stove please?
as far as the popping sound, that would the spark module.
SOURCE: Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
SOURCE: oven not reaching correct temp
It isn't a design flaw. It is an air pressure switch. Main fan not running OR oven is dirty and the tube to the air pressure switch is clogged. Dirty ovens aren't a design flaw. I saw it once a week. Five minutes clearing the tube and you back in business. Hope this helps.
SOURCE: GE oven temperature is not true, and needs to be reset.
The temperature is within manufactures specifications.
By that I mean that the majority of manufactures allow a tolerance of + or - 10 % of the set temperature.
So, in your case, 10% of 350 degrees is 35 degrees, thereby showing that the actual temperature you are obtaining is well within the 10% allowance.
I hope this helps you .
