After self-check this code came up but do not know what to do
SOURCE: to get reset code for errors on brother dcp 8040
6E
Heater temperature does not go up
enough.
(Slower temperature rise rate than 2°C/5
sec. is detected.)
To cancel the trouble status follows these steps:
STEP1 .Press MENU
*,2,8,6,4
STEP2.The machine beeps for approx.
one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in
the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry
from the keys.
STEP3.Now you are inside the
simulation Press 01 to reset the
trouble status.
STEP4.To exit the simulation press 99
• Pressing the 9 key twice
in the initial stage of the maintenance mode makes the machine
exit from
the maintenance mode, restoring it to the standby state.
• Pressing the Stop button
after entering only one digit restores the machine to the initial
stage of
the maintenance mode.
If again 6E occurs try to check the halogen lamp or power supply PCB.Contact authorized technician to do this checking.
SOURCE: I have a Brother DCP-9040CN. Its not grasping the
You can try applying belt dressing to the rubber wheels that pick up the paper. It comes from an auto parts store, and is made to apply to the fan and generator belts of automobiles, to stop them from slipping. You may have to reapply it every few months.
SOURCE: Envelopes are getting wrinkled when run through
Unfortunately when feeding envelopes it is quite common for them to wrinkle a little simply because of the way envelopes are folded. The paper is thicker in certain areas because of the folded paper and the glue that holds the envelope together. You could try different brands of envelopes some don't wrinkle as bad as others but in my 37 plus years of working on copiers and printers I have never seen any envelopes that won't wrinkle a little, you may just have to live with it.
SOURCE: how to check the toner level of Brother printer
It has no accurate measure of the toner left, it is reset when you put in a fresh toner and just counts prints. The Brother shines a light thru a little window from right to left and when the toner is empty the light shines thru and it says it's empty.
Testimonial: "Right to the point. Thank you."
SOURCE: error code 6a on a brother dcp-7020 fuser unable
you need a new fuser. Not easy to install for most people I think I have a used one for sale for 40.00 805-520-3003 steven
