WIC Reset Utility is the only solution to the problem. Caution! WIC Interface uses Technical terms for settings and have many factory level setting options, which should not be disturbed by an end-user, so carefully use WIC only to reset INK Levels and Pad Counters. Better refer screenshots of WIC from internet before trying, me too have an L210, the solution is 100% sure and Applied, I am sure you will be thanking me..
This is helpful to me, i have downloaded WIC Reset Utility from here:https://resetkey.net/download and reset my printer INK Levels successful, thank you rajiv6089
Here is the
Epson L110 L210 L300 L350 L355 resetter download olution follow the post and screen shot
SOURCE: epson c43sx current ink levels not shown in the properties
See my answer to your similar question:
t is possible that the ink cartridges in your printer (especially
applicable if you are using refilled or compatible carts) can not be
read by the printer. Some compatible cartridges have a failure rate as
high as 30% and so it is very possible that the machine either does not
see the cartridges or can not read them.
Replace the cartridges
with genuine Epson ones and try again. The genuine ink will also help
to clear any hardening cheap ink in the print head.
SOURCE: Ink Levels not showing
what operating system are you using? are you getting an error light on the printer?
SOURCE: epson stylus d92 won't show ink levels
hello
Download the the driver again and reinstall it.
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=wsMoc1iChVGcisk9ncQeIBmTUU002FxOg74o84TjGD6F5MAU003D&tc=6
SOURCE: I just re inked my Epson styles Photo RX500. All
what is the error message? try to turn off and on your rx500. note for an epson printer it requires all inks inorder for it to function or else it will be on an off line state
SOURCE: Epson Stylus C88 - New
You should run a nozzle check to verify if the heads are printing all the inks correctly. If the pattern is incomplete you need to run head cleanings.
