Water not getting into the dishwasher. error code .10
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
SOURCE: error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
SOURCE: Hi, I have an aeg 60870 dishwasher showing error
Sounds like the Anti-Flood system activated (polystireen float at base of machiene coupled to a micro switch) the purpose of this system is to put the drain pump on and stops any other function on the machiene. The anti lood system activates when any amount of water appears on the bottom (caused by leaky pipe / blokked pipes / spills etc.) . Dry the water and rectify the leak. This should solve the problem.
SOURCE: My AEG dishwasher - Favorit no. 60870 sensorlogic
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
SOURCE: AEG Favorit 60870 Dishwasher not starting
Matthew, in most cases when a circuit board repeats the same action over and over, there was a short and loss of communication with associated controllers. Obviously you have power to the control unit, so that means the instructions from the controller to the solenoids is lacking. You are correct in assuming the board needs replacement, however you must determine is the cost for replacement is worth the time and effort. An old machine means one repair after the other. If its relatively new; then it may be worth it.
