SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
SOURCE: need to reprogram my sentry v360 safe. forgot my code
http://www.sentrysafe.com
for instructions use link above.
mj
SOURCE: sentry codes v260
You should have received two skeleton keys when you bought the safe. They will open the safe without the key AND without the code. If you don't have it, the only solution is to get help from Sentry. By following the instructions below, they will send you a skeleton key for your safe.
First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe (outside). Send this, a notarized letter(last name must be different) stating you are the safe’s owner, and a check or money order or $8.00 (U.S. funds) to:
Sentry Group Dept. 200
882 Linden Ave
Rochester, NY 14625-2784
If using a credit card (Visa/MasterCard only), call 1-800-828-1438.
SOURCE: sentry safe, enter codes and nothing
These safe are easily opened by a good locksmith. So if you have items in the safe you need to get out a safe and vault tech could drill it open and repair it for a small fee. I really don't think it is the chip probably just a stuck solinoid.
