L-glutamine powder. L-glutamine is an amino acid. A teaspoon of L-glutamine powder in four ounces of water takenwith each meal can help heal gastritis and even stomach ulcers. Do a search for research on this supplement if you want to find the studies. I know several people who were able successfully to wean themselves off Prilosec (which can lead to osteoporosis and other problems) by using this supplement. It's a naturally occurring substance--it's already in your body. After your esophageal epithelium heals you can stop taking glutamine and restart for short periods if the reflux recurs.
That's not to imply that supplements are not important. Quite the contrary, I believe they are an very. In fact, I believe that supplements can work as the difference between mediocrity and greatness. Supplementation has really developed and offers the natural bodybuilder incredible metabolic company. From the Testosterone Booster enhancers to the glutamine and creatine, we truly fortunate to have such a variety of quality products at our disposal.
It is not OUT2, but rather OUE2, which means your chefmate needs to re calibrate. To do that you will need the following:
a 2000 grams weight or 4.4 lbs, I used a 3lbs protein jug unopenened and a 600 grams glutamine bottle unopened.
Ok so turn your scale off then:
1) press the ON button and leave it press while simultaneously pressing once the TARE button (though it may need more than one or maybe leaving it press for a few secs thought try just hitting it once first), release the TARE and you should see a CAL on the screen (top left), release the ON and it will read:
2) the number 00000 on the first line will appear, click TARE
-this calibrates no weight first-
3) then it will read you another weight mine read 2000 grams, put that weight on top of the scale (NOTE every scale uses a different weight to calibrate i am giving you mine) once you put it there hit tare and it should read PASS
4) Remove the weight and it should read "0", mine read first 1 grm so i had to re do it again until i got 0.
5) You can try weighting different unopened things that you know the weight of, but if not just turn it OFF then back ON and it should read "0"
Congratulations your scale is now calibrated and ready to use again!!!!
NOTES: i have the electric scale if the on tare button does not works for you it may need a different combination to calibrate.
