SOURCE: makita cordless drill # 6233
ya. see www.ereplacementparts.com for price & cost of the parts.
SOURCE: makita 12v impact driver- no reverse
I would suggest that you go to Makitatools.com and type in your model number and look at the breakdown for complete disassembly procedures. The only problem it could be it the tab on the switch or the shift lever is broken I would have to think it is the switch. Let me know if I can help more.
SOURCE: how to replace forward and reverse switch
If you are mechanically inclined you should have no problems but if not this is involved. First I would recommend going to the Makitatools.com website and on the right side type in your model number and look at a breakdown for this unit. To start with you have to remove the chuck, then the collar with the 2 springs under it and then remove all screws from the housing separating it carefully so none of the parts jump out. The switch is polarity sensitive so make sure of the wiring. If you still want to tackle this let me know and I will go into more detail on this. Good luck
SOURCE: Drill only goes in reverse
either the switch lever is broken or jumped out of the recess. suggest going to makitatools.com for a breakdown.
