Not printing, printer error. See documentation and call service.
SOURCE: EPSON STYLUS CX6600 - PRINTER ERROR SEE YOUR DOCUMENTATION AND CALL SERVICES
Could be the waste ink tank is full. Take a look in at www.fixyourownprinter.com. Aslso a useful download is the SSC Epson utility that carries out many 'managment' functioms and has its own forum also www.ssclg.com And last but not least - Epson customer support
SOURCE: My Epson Styluss CX6600 won't charge
This may be very simple. Turn the unit off and lift up the top. On the forward side of the unit you will find a little 'slider switch'. This is the scanner unlock - toggle the switch back and forth several times and leave in the unlock position. Turn on the printer and all will be well.
SOURCE: error message
OK guys quite a simple one....
with the printer on press & hold both the small red button ( far right ) and the green, colour copy button. Whilst still holding press the power button wait till the unit powers off. Press the power button again, shortly after the unit powers on, the lights flash, let go of the two buttons your holding. The screen shoul dnow say "Init EEPROM" if it doesn't repeat procedure till it does. Now press the green colour copy button once, screen should now say "Push power sw" Press and hold the power button, the unit will power off and on again, now release the power button and your printer should be working again. Now you should change your waste pads......
SOURCE: printer error
follow the link for downloads, faqs,troubleshooting, documents and manuals.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41664
Mark
