GE 29878GE1 Digital Answering Machine Logo
A
Anonymous Posted on Oct 03, 2014
<!-- from fixya rte -->Set it for 6 rings and message pick it up - GE 29878GE1 Digital Answering Machine
1 Related Answer
Anonymous
  • 99 Answers
  • Posted on Jun 02, 2008
SOURCE: setting the number of rings
try this page...
http://images.owneriq.net/download/images/9/99351467-0ae8-2444-1dd3-486419692db0-000001.png
2answers
Phone rings twice & then goes to message, I want to extend ring as long as possible
not knowing what phone it is make this hard. It will be in the setup menus but most systems will probably be limited to 6.
2answers
Voice Mail
go iin option under ringers cheak to see whats its on before voise mail picks up 1 3 6 10 ? isnt it in the optimns menu or if u have seprate unit for voise mail cheak setting on that beofre it grabbs the call does that help
Does anybody know how to increase the number of rings on my dect1735 phone it only rings 3 times and goes to message bank.
press menu
select answering set up move to rung time select menu add ring time press menu and then press exit to save
How do I increase the rings before message answers?
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
thanks
# of rings
The place to set rings to answer is # 506 (VMS hunt delay)selecting either 1 for the day schule or 2 for the night schedule. You'll also want to check #507 (VMS hunt schedule) to make sure your line is in the correct schedule and not following the alternate schedule.
8helpful
Would like to increase number of rings before answering machine comes on.
Set answer machine on a kx-tga101s to pick up on 8 rings
From the manual, it doesn't look like you can reset the ring count with this phone set.
You can find the manual at www.panasonic.com
Reply back if you have any further questions, or feel I have missed something.
Setting jx200 to manual and have ansewring machine connected.
I normaly set all my fax machines on fax only,but I change my incomming ring count to more than 7 rings,but less than 11 rings,this allow you to have time to answer you call before it goes to fax.But you can set it for manual.
Press the "receive mode/resolution button untill it show on the display-manual,fax only or ansering.
Yes you can use the fax and answering machine when you are out of the office.
Set you answering machine to pick up after one ring,the message must not be longer than 15 sec.
If you leave set your receive mode to answering mode
Hope this will help you
Fax feature
You have to set the printer to pickup 2 rings higher than your answering machine. If the answering machine picks up on 4 the printer should pick up on 6.
I believe the menu should be Setup button - down arrow key until you see basic fax setup and press ok - down arrow key until you see rings to answer and press ok - change to 2 higher than answering machine.
Now you should receive faxes and calls!
1helpful
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
