Question about Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V
Pool pump The pool pump is not working. I have a new pump and when I hooked everything back up and flip the switch to turn it on the motor makes a short noise like it is going to turn on and then is shuts off.
  • 22 Answers
Check to be sure that the motor wireing is the same as the wireing going to it 115or230 most motors can be converted look on motor for wire diagram.
Posted on Jul 10, 2009
6ya staff
SOURCE:
Emerson 1081 pool pump makes buzzing noise when i turn it on wont start
Either something blocking the impeller / shaft, from turning or the motor failed.
You can try to manually assist the motor, by removing the small cap at the back of the motor, getting a flat blade screwdriver, and right when you flip the switch (get a helper) turn the shaft clockwise while it buzzes. If it takes off - possible Bad Capacitor? Try a couple times if it doesn't take.
if bad capacitor, make sure you get the exact replacement, or 'Slightly Greater' will work - and I refer to the MFD number. Don't go smaller!
May 29, 2014 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Switch is turned on but pump would not run. shaft turns by hand
It's junk made by Hayward. I've gone through two motors and am starting to hear the familiar noise of another motor about to fail.
Jul 05, 2012 | Hayward Pool Products Economy 1 Hp Above...
I have a hayward pump model SP2610X15 that will only hum when turned on. I replaced the capacitor, it did not help. What else could be the problem?
DIRTY START switch or the motor is locked up, breaker off ! remove motor from tank body and see if the motor will turn over if it does could be the switch or the motor is shorted witch there is no fix but a new or rebuilt motor. search your area for your local pool pump motor repair guy with free testing..
Jay the pool pump motor repair guy longwood Fl
Apr 02, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
I have a flo master xp2 / 48 frame / 230V / 2.5 hp / 2 speed spa pump. I accidentally hooked switched the high and common lines when wiring the electricity. The low line was done correctly, because they...
You shorted the 230 lines at the motor terminal board. If you are certain you have reset any and all breakers feeding the spa and that the 230V is getting back to the pump motor then you blew the winding leads as you shorted the motor. While it is possible a motor shop could repair the leads it is far more likely the damage caused will cause the price to be that or more of a replacement motor.
John
Sep 21, 2010 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Haywood Max-Flo Pump (self priming)for indoor inground pool 3/4 HP ... model C48J2N131A -- yesterday turned off master breaker switch to everything in the pool area (including power to pump) so that I...
The motor may have blown the start capacitor. It is the black cylinder about 1-1/2" dia x 2-1/2" long. Look at the end with the wires for a small hole. Is it blackened or have a hole blown thru? If so replace it. Otherwise have a local electric motor repair shop look at it for possible repair or replacement.
Sep 06, 2009 | Hayward Pool Products Hayward Max-Flo 1...
My new AO Smith 2HP pool pump won't pump water, just hums
I'm guessing that you replaced the motor that goes to the pump, not the pump itself. You know the motor works just fine. Is the motor rotating in the correct manner(clockwise or counterclockwise) in relation to the rotation of the pump? Have you checked the pump to see if the impeller is working/rotating? Is the motor hooked up to the pump correctly, so that the motor is turning the impeller? Are all connections to the pump tight, so there are no suction leaks? Have you primed the pump and purged it of any air locks?
Aug 11, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Pump hums when switched on but does not work more than 20 seconds
hi i had the same problem with my booster pump motor it hum but did not turn. to make a long story short see if there is a metal cap on the back of your motor if there is pry it off and you should get to see the shaft turn the shaft with a screwdriver if it has a notch in it or if it don't turn the shaft anyway you can and make sure it turns easy. my shaft was tight as hell but i got it to turn and it started right up again and i had no problem. the hum means it is stuck and it shuts off because the breaker is tripping and after a few seconds it will click back on again, hope this helps
Jul 06, 2009 | Emerson Pool & Spa
Pool pump is not working
The motor capacitor is bad. This usually means the motor is shot. It's hard to get capacitors for a quick fix
Jul 04, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Motor hums then clicks off
Has the motor seemed a little slower in starting than usual? If so then you probably have a weak or defective motor capacitor. Try switching out with a new one.They are inexpensive.Try to turn the motor shaft at rear (under end cap) while it attempts to start. If the motor kicks on then replace capacitor.
Apr 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V Logo
557 people viewed this question
Top Jacuzzi Pool & Spa Experts
Mike
john h
US Parts Center
US Parts Center
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
