When using program 6, the time stated is 2:29 and after two minutes it stops and shows F8 and E1
SOURCE: F8 Error
F8 code means that washer has not emptied out fully. Open the door,empty water manually, clear the filters and the drains. Close the door and then hold the start button,until it will restart. Good luck !
SOURCE: error
E1 IS TIMEOUT CODE I WOULD CHECK FOR WATER SUPPLY, KINKED FILL HOSE FIRST, CHECK CONNECTED TO COLD SUPPLY AS HOT MAY NOT HAVE ENOUGH PRESSURE. IF ANY DOUBT ABOUT WATER SUPPLY/PRESSURE TAKE HOSE OF M/C END AND RUN INTO A BUCKET GOOD LUCK.
SOURCE: Whirlpool ADP5966 fault code F8
just choose another prog setting and hold the start button in for a few seconds.
SOURCE: Dishwasher keeps stopping
sir i think the problem would be in any of the three areas. any prob in these areas would lead to the problem u specified
SOURCE: error message f8
Hi girijyo,
F8 means you have a blockage in your drainage pipe, try cleaning all the filters and the drains, then closed it up, held the start button until it restarted. let us know if this works.
Regards
R.K.
