I was downloading fro my car cam when windows shut down. on restarting went to a blue screen with the notation HD locked gave me several choices to restart but non work for me.. I CAN get into dos can anyone help >
SOURCE: My computer does not shut down
Ok
Gonna try and teach you some basic programming :-).
What the following will do, is create you a Desktop Shutdown Icon, which when you double click on it, will hopefully shut down your PC rather then restart it.
So here's how to do it :-).
1. Right click on your desktop and select new > shortcut.
2. In dialog box type “shutdown –s”
3. Click next to continue and then type a name for shortcut (IE Shut Down PC) and click finish.
Now you should see the shortcut on your desktop and will hopefully solve your problem.
SOURCE: how to keep number lock on after comuter is shut down and restart
SOURCE: ndisio.sys problem
Hi there
Boot up in safe mode ( press F8 on start up ) then go into system restore and reset your machine to a time before the problems occurred
Good luck and thanks for using Fixya!!!
SOURCE: Windows Vista will not start up
Please have a look at this link to see MS's recommendations for startup problems in vista.
And since you can't even get it booted at the moment, see here for an explanation of that 0x...24 error code, which indicates a problem with the file system driver or the drive itself. You will need to run the chkdsk utility from a recovery disk or recovery console to determine this.
It's possible that since your optical drive is not functioning, that the driver for that drive is causing the problem, but if you don't have the recovery console installed and can't run a recovery disk, you may have to take it to a shop just to get it booted on another hard drive. (see similar discussion here)
There is a hotfix available for systems that receive this error code, see here
Because there is a hotfix available, you might be able to get Microsoft support for this problem by following the hotfix link in that last link.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: Blue Screen Comes and Computer (Dell 1525) Keeps Restarting HELP!
are you using windows? just reinstall your operating system, this may keep it back to normal
