I have a cub cadet 1320hydro. 38 inch cut how do I put on deck belt
Un hook front drag links from deck move tractor forward an inch or two , loop belt around pulleys , push tractor back and reinstall drag links , if belt on mover deck has broken , it's gonnabe easier to remove deck from under tractor , then take off foot guards on sides , using a 5/8 socket and b-bar move tensioner till you can slide off belt from one pulley , reverse to install new one
SOURCE: cub cadet model LT1045 belt coming off the pulley
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING! I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing. Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw. It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!! - Mike If you for some reason you cant
