I am looking for a particular part number. I hopefully can find the part with the correct part number
SOURCE: lanier LD 325 Printing labels
4 x 6 might be too short for that copier to run on. The bypass tray might take it if you load it so that the 6" side is the longest end that the copier is feeding throught the machine.
If you have it interfaced as a printer, goto avery.com and download their label making software and find the template that matches your label stock. The software works with Microsoft Office files as well.
SOURCE: I have a Lanier LD 232c. Every print job we try to
Make sure that all the paper trays have the correct size and direction (portrait or landscape) in both the copier and print driver.
SOURCE: sc 544 lanier ld 122
CALL FOR SERVICE YOU WILL NEED NEW THERMISTORS NEW THERMOSTATS AND MOST LIKELY HOT ROLLER,CLEANING ROLLER AND HR BEARINGS COST OF TIME AND PARTS WILL BE 400 TO 500
