Microsoft Xbox 360 Console Logo
Posted on Jul 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lower red light appeared but did not flash. System froze.
PSR has already repaired my unit 2 times. Is the 3rd time a charm? I started my 360 this morning to continue playing Mercenaries 2 that I been playing successfully without problems for the past week, and a red light appeared lower right but was not flashing. Any thoughts, suggestions?
  • mthofer Jul 05, 2009
    Thanks Huuum...unplugging everything and plugging all back in was the first thing I did but unfortunately received the same result. And I will not open the console and mess around with the hard drive. I've swapped hard drives from my Mac G4 but do not know enough about game consoles. I have a service call into PSR and I'm awaiting a shipping label to once again return my console to them for repair. I was actually told by one of their reps that what I'm experiencing is usually fixed after the 2nd service. I guess they were wrong.
Anonymous
Level 3:
  • Master 750 Answers
  • Posted on Jul 04, 2009
Anonymous
Master
Level 3:
Answers
750
Questions
0
Helped
491089
Points
2063
You are having a minor hardware failure- you might need to get it repaired but FIRST follow the link i give you-- it has a list of steps to take to potentially fix the problem- if it continues to light up the you have to send it in. Source(s): http://support.microsoft.com/kb/907535
2helpful
2answers
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Xbox 360 wireless adapter 1 red flash of light
Hi Sir
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Please Rate
E7 code appears turn on button flashing red
This is a fairly common problem with the xbox 360 units, you will need to call 1-800-4-My-Xbox for a repair. Most of the time the repair is free under warranty.
Thanks
Test portion of message, have been having problems with the system today, please ignore this part of the message.................
3answers
My xbox360 will not stop flashing red
Sorry, only answer is to phone xbox and arrange to have repaired. Good news is its all free and should be back with you in 2 weeks.
FLASHING RED LIGHT ON 360
Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light may indicate that the power supply is too hot or it has already overheated. If that is the case, you should let the power supply cool for several hours in a well-ventilated space. Turn off the Xbox 360 console and don't turn it back on while the power supply is cooling. This will allow the power supply sufficient time to cool. As soon as the power supply has cooled off, the power supply light will change from red to orange, and you can turn the console back on.
If the power supply light is still red after you have let the power supply unit cool in a well-ventilated space, the power supply unit may require replacement. You can contact Xbox Customer Support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to replace the power supply.
Make sure that the power supply is plugged in correctlyFor further details go to this link
http://support.microsoft.com/kb/906101/
One red light appears no picture
hello sir
Solving Your Red Light Flashing:
Please Rate
3 red flashing lights
When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply is button is red than you need to replace the battery or check the connections.
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. If you are experiencing this problem, you can submit a console-repair request online.
Hopefully your system is still under warranty.
For step by step troubleshooting directions please read the attached link and Happy Gaming!
http://support.microsoft.com/kb/907534
4helpful
11answers
1flashing red light
one red light is also the E71 error as well.
Xbox 360 freezes
There are some recalls on this unit. Call microsoft for help.
1helpful
3answers
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
