Question about Building Materials
Can i paint my garage doors?
Clopay doors
    Master:
  • 401 Answers
Yes they can, but prep first , a light sanding with a scruff pad and prime and paint
Posted on Jan 10, 2015
  • 1 more comment
  • atp1962 Jan 10, 2015
    Painting: Your steel garage door can be painted with a high quality 100% acrylic latex (flat, satin, or semigloss) exterior grade paint. Before painting the door it must be free of dirt, oil, caulk, waxes and mildew. Do not use any type of oil based paint or Alkyd modified
    http://www.homedepot.com/catalog/pdfimag...
    Add a CommentThis link may help
  • 5,748 Answers
Clopay's steel garage doors can be painted with any high quality exterior latex paint. Wood garage doors must be painted/stained on all sides prior to installation. Most models are available factory primed. Clopay recommends wood garage doors be re-painted every 1 to 2 years (more frequent refinishing may be required in high moisture areas).
Posted on Oct 02, 2014
6ya staff
SOURCE:
My garage fiberglass door was powerwashed by a guy painting the garage and now it has fiberglass fluffies all over it. How can I get rid of them and seal it? I am not handy.
Re power-washed garage door (Katie):
It sounds like the power-washing pressure, temperature and chemicals loosened the bond between epoxy and glass fibers.
Buy a large container of fiber-glass resin, with activator / hardener.
Brush this on, mixing small amounts as you progress (sets quickly). When completely cured, lightly sandpaper and re-coat if necessary to remove furriness.
Paint with undercoat and weatherproof surface enamel paint.
Acetone solvent can clean (messy, sticky, smelly) resin.
Edit: Wear protective clothing - those fibers itch!! :)
Sep 10, 2017 | Miscellaneous
Can dried paint cause garage door to stick and bend tracks
Hello, yes if you close the door when the paint was still wet, can cause all kinds of problems with sticking and bending tracks, warp the door out of space.
Nov 03, 2015 | Cars & Trucks
The doors on my S80 are stuck solid at minus 4 ???? help
Can you push it into a heated garage? Maybe shooting some warm air at the doors-even a hair dryer-maybe a garage floor heater that blows hot air. I would suggest a propane torch, but then you might have to get a $2000 paint job! Overkill?
Jan 16, 2013 | 2008 Volvo S80
The door was working fine for 8 years, last week it went down to about 2 inches from the floor, then went back up. No obstructions. I the started to adjust the chain...bad idea. Now in is inconsistant...
If this is a wood garage door (as opposed to steel), the problem may be that the door has become heavier. It might even be sagging enough to interfere with smooth operation. The added weight could be from being recently painted or the paint finish has gotten to the point where it's not sealing the wood anymore, so it's soaked up the summer humidity. Call an overhead garage door service company to take a look at it. They can probably make the adjustments to get it working. Then you might want to wait until a couple of weeks of dryer weather in the fall before you repaint the door.
Aug 14, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door take about 20 button pushes to open all the way, what is the spring supposed to look like? Is there one on each side or just one piece that should be connected? I just don't know if my spring...
to find out if your spring is broken wthout knowing you can spray a paint line all across the spring and then when you open the door the paint should go into a swirl if the spring is good if not the spring is broken.
Feb 02, 2010 | liftmaster Chamberlain Garage Door Opener...
Building Materials Logo
328 people viewed this question
Top Building Materials Experts
Tom Chichester
Lawrence Oravetz
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
