I have a samsung s3 gt-i9300 i cant make or get calls it says emergancy calls only
Your Samsung Galaxy S3 must be restricted to some specific network. That is why it allows only emergency calls when a SIM card from some other network is inserted in. You need to unlock your Samsung Galaxy S3 to make it work with all SIM cards. You can unlock your Samsung Galaxy S3 safer and easier using unlock code. You can get the accurate unlock code for a Samsung Galaxy S3 from Unlock-Zone.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
Method 1:
1 - Switch ON your Samsung Galaxy S3 with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy S3 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy S3 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy S3.
3 - Compose : #0111*CODE#.
SOURCE: MobileUnlockGuide.com
Could it be in flight mode if so turn the flight mode off
SOURCE: My samsung Duos gt-b5722 not
Try other sim cards in the phone to be sure the problem is not from the sim. When you are sure the problem is not from the sim, try to reset the phones's factory settings. If it still does not work, then flash the phone.
If the fault was detected to be a sim fault, then get another line of the same network, and call your mobile service operators.
Hope this was helpful?
