6250 watt briggs & stratton generator blow breaker when power switch turned on fire from outlets
Sounds like you have a dead short. Check the outlets for any debris, metal or copper. Check the backside if the outlet for anything grounding onto the unit. The breaker is tripping to protect the outlet and anything plugged into it. The fire shooting out of the outlet is an arc flash caused by the dead short. You can also try disconnecting and replacing the outlet . If the problem persists, disconnect the starter and try to bench test it with a multimeter. I hope this helps. Good luck.
