E
Emma Solis Posted on Oct 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to print a web picture on 8 x 11 on cassette 2 on Epson XP-810 but tells me to load paper in cassette 1, which is only for photo size paper. Cassette 2 is regular size paper. How do I fix this?
Steve Mason
Level 2:
Sergeant:
  • Expert 311 Answers
  • Posted on Feb 18, 2015
Steve Mason
Expert
Level 2:
Sergeant:
Answers
311
Questions
0
Helped
57655
Points
687
Change paper size in print settings
5 Related Answers
Anonymous
  • Posted on Dec 27, 2008
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Anonymous
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Anonymous
  • Posted on Apr 20, 2009
SOURCE: Check paper size
Change the default setting for the paper size on your computer to letter. The paper size need to match on the printer and computer for it to work properly.
Anonymous
  • 1959 Answers
SOURCE: Paper size
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
themadczar
  • Posted on Nov 27, 2009
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Trying to print a picture from the web on XP-810 epson on regular 8x11paper, printer tells me load paper on cassette 1 but cassette 1 only takes picture size not 8 x11. Cassette 2 is where the 8 x11 i
I Just right click on picture select save as. I now have a copy in my pictures. right click on picture select print, on the drop down window select paper size A 4 is 8X11 if it asks print to paper size click ok.
My Epson Artisan 7-110 keeps trying to print to cassette 2 (small cassette) even when copying A4. A4 paper is loaded in Cassette 1. Why?
If its not a setting problem, it may not be communicating with your computer properly, try turning it off, wait a little while and turn it back on, if that doesn't work delete your printer off your computer and re install it, Is it the default printer on your computer? some times if you run more than one printer from your computer there's a conflict which can make it behave in weird and wonderful ways.
Trying to print - got Warning message THe paper cassette is no set correctly. Check for any objects in the cassett of block the cassett path and insert correctly
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
How can i put 4 photos on A4 page-using an epson rx700
Go to your printers and faxes (xp), or Devices and printers (Win7) folder
Right click on the RX700 and choose Printer Preferences
Select A4 as the paper size
Select Page Layout tab and select Multi-Page and select 4 (default is 2)
Select 4 copies
Print away!
Alternatively, if you're using Windows, use the Office Picture manger, Picture and fax viewer of the like, and select the multi pictures setting. If you're printing one photo 4 times, remember to select 4 copies, as you're telling the app to print ONE pic in a 1/4 of the A4 page. You need 4 copies to fill the page with the same photo.
Hope this helps.
1helpful
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
I am trying to print a 4X6 postcard from my epson stylus photo r340, and it just won't take that paper. It prints 8 1/2" X 11" just fine. Any ideas?
Change the printer settings: Right Click the Printer, click Printing Preferences, on Paper Size click 4R or 6 x 4 photo..SOLVE
My HP Photosmart D7260 is not printing pictures
Ok! You didn't tell me how old is the printer, what type of paper and what size you tried to print so I'll do my best to help.
Please note:
  • The photo paper cassette cannot be installed when printing on paper loaded in the in tray.
  • The 7260 printer support 5x7 media only when printing from a computer with the printer software installed.
Loading 5 x 7 inch paper in the HP Photosmart 7260 printer
  1. Lift the main cover of the printer, and slide the paper width guide as far to the left as it will go.
  2. Lift the Out-tray and place a stack of paper in the In-tray.
    • Load the paper with the side to be printed facing down.
    • Load paper in the portrait orientation with the shortest edge feeding into the printer.
    • Do not use too much or too little paper. It may be difficult for the printer to pick up a sheet of paper when there are only one or two sheets in the in tray.
    • Use one type and size of paper at a time. Do not mix paper types or sizes in the In-tray.
  3. Push the paper into the printer as far as it will go without bending.
  4. Lower the Out-tray.
  5. Adjust the paper width guide to fit snugly against the edge of the paper without bending the paper. The paper width guide holds the paper straight as it feeds into the printer.
  6. Close the main cover.
Load 4 x 6 inch (10 x 15 cm) photo paper in an HP Photosmart
Use the photo cassette to load 4 x 6 inch (10 x 15 cm) paper. To print borderless photos, use 4 x 6 inch photo paper with a 0.5 inch tab (10 x 15 cm with 1.25 cm tab). This allows the photo to print without borders on three sides and with a small border on the bottom edge that can be torn off.
HP does not recommend printing borderless photos on plain paper. Also, remove any paper from the In tray before inserting the photo cassette into the printer.
1. Lift the top cover of the printer and remove the photo cassette from the sheath.
2. Place up to 15 sheets of photo paper in the photo cassette with the side to be printed facing down. For tabbed paper, insert the paper so the tabbed end goes into the cassette first.
3. Lift the main cover.
4. Slide the paper width guide all the way to the left.
5. Lift the Out tray and remove any paper that is in the In tray.
6. Line the photo cassette up with the far right edge of the In tray.
7. Gently slide the photo cassette into the printer until it snaps into place.
8. Lower the Out tray.
9. Slide the paper width guide to the right until it cradles the photo cassette, then close the main cover.
If the Out of Paper message appears on the computer and the product stops picking up or feeding paper.
Step one: Reset the product
1. Without turning the product off, remove the power cord from the back of the product.
2. Wait 30 seconds and then plug the power cord into the back of the product.
3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
3. Tap the stack of paper on a flat surface to align the edges.
4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
NOTE: Do not load too much paper in the product.
5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.
If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver
The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
1. Open a document in the program being used to print.
2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
3. Click the Paper/Quality tab.
4. Choose the appropriate paper size from the Size is drop-down menu.
5. Choose the appropriate paper type from the Type is drop-down menu.
6. Click OK and then click OK again to print the document..
7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened.
Step four: Clean the rollers
1. Turn off the product and unplug the power cord.
2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
5. Close the access door and plug in the power cord.
6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
If your product is less than a year old, don't worry, HP can trace the product when you provide the model and the serial number and will help you if it is in warranty. No prove of purchase required.
Epson stylus pohoto 830u paper feed
I'm afraid this series of printer (810 -830) doesn't handle heavy photo paper well - which is a bit strange for a so-called photo printer. If you hold each sheet and help it to feed it will work. But ...... for goodness sake. Your best bet is to sell it on e-bay and buy something that will handle heavy paper.
Printing on 4x8 cards
There are two different ways to create a custom page size within the Epson printer driver on Windows 2000 or XP. The method you need to use will vary depending on what type of driver is installed.
CREATING A CUSTOM PAPER SIZE IN SERVER PROPERTIES
This method will create a new page size accessible by all printer drivers installed in Windows.
1. Open the PRINTERS (2000) or PRINTERS and FAXES (XP) window.
2. Click on FILE, then select SERVER PROPERTIES.
3. On the FORMS tab, place a check beside CREATE A NEW FORM.
4. Input a new name for the paper size. Enter the desired height and width, following the existing format (#.##in).
5. Click SAVE or SAVE FORM to add the new form size to the list, then close SERVER PROPERTIES.
6. Right click on the printer name and left click PRINTING PREFERENCES.
7. Look for PAPER SIZE. (Depending on the driver in use, this will be found on the MAIN tab, the PAPER tab, or under the ADVANCED button). Select your custom paper size from the list.
8. Click APPLY to save this setting, or OK in Windows XP.
NOTE: If your new custom size is not available on the list of preset paper sizes, it indicates that the new size is either too large or too small for the driver in use.
CREATING A CUSTOM PAPER SIZE WITHIN THE EPSON DRIVER
This method will create a custom size within the Epson printer driver only.
1. Open the PRINTERS (2000) or PRINTERS AND FAXES (XP) window.
2. Right click your Epson printer name and left click PRINTING PREFERENCES.
3. On the MAIN or PAPER tab, select USER DEFINED from the PAPER SIZE drop down box.
4. Enter the new custom size and give it a name. Click SAVE to save the new size and OK to return to MAIN.
5. Click APPLY to save the changes (OK in Windows XP).
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
