SOURCE: Change voice mail/greeting
Which voicemail do you have?
dial into mail, it will say....
welcome to partner mailvs
welcome to partner vocie messaging
wem\lcome to partner messaging......
which do you have?
SOURCE: Voice mail problem
You need to reset the password
Type in on telephone keypad:
5555#*
999#
999997#
Select Option 8
Select Option 4
Type in extension number you’d like to change followed by #
Select Option 5
Go to telephone you’ve just changed and type in 5555
Enter extension number followed by 997#
Select Option 3
Select Option 2
Select Option 3
Enter new security code followed by #
Confirm new security code followed by #
Hope this helps, Karen
SOURCE: i don"t have voice mail.
Pls fist put you sim in deffrent mobile and call to you number and you call is going to voice mail so going to voicemail so ok Thats you mobile problem but if you no going voice mail so active you voice mail device call to service proivedar of you network ...ok
SOURCE: the time stamp on voice
Hi, I have inserted the manual for this phone below:
User Guide
http://www.vertical.com/media/pdf/UserGuides/DX80-DETUG.pdf
Analog-User-Guide
http://www.vertical.com/media/pdf/UserGuides/DX80-Analog-User-Guide.pdf
Programming Manual:
http://www.asksts.com/DX80/Docs/ProgrammingManual.pdf
Has im not 100% confident on phone, it best for you to have a look you may understand it better then me.
Hope i have helped in some way
Alan
SOURCE: I need to know how to forward calls from 1 line to
To transfer calls you keep the line open, hit transfer, message, and type in the extension.
enter voicemail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voicemail message, you must press 3, delete the original message and reset the message followed by the #.
have uploaded a video off http://www.abbeytelecom.com which explains Voice-mail in more detail, if you are operating a differant system then I can only suggest that you rafer to the relevant operators manual
To enter voice mail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voice-mail message, you must press 3, delete the original message and reset the message followed by the #.
I have loaded a video explaining VM, at www.abbeytelecom.com there are 64 videos which will help you with any other issues that may arise.
