The machine won't fill with water and after a little while it flashes e02 and f01. I have already removed the front cover and cleaned the filter. I have also cleaned out all the drain hoses and checked and cleaned the inlet valve. When I tried to start it it did the exact same thing.
SOURCE: Washer won't fill in rinse cycle
REPLACE YOUR WATER INLET VALVE(HOT,COLD WHERE HOSES ARE)IT'S NOT OPENING ALL THE WAY TO LET THE WATER FILL UP FAST,LET ME KNOW HOW YOU DO-MIKE
SOURCE: Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
SOURCE: Washer won't stop filling with water.
not really but you may want to take the back off enough to follow the clear air hose back there into the back of the control panel and either blow through it or use a small blast of compressed air to clear the cup that attaches to the tub. Powder detergents tend to block this line and your pressure switch can't detect the pressure anymore so the switch is fooled and let's the water inlet valves continue till it overflows try that and you may be surprised at it's results. Good luck. If that doesn't do it then it's the switch but i'm pretty sure it will fix ya.
SOURCE: Maytag Neptune MAH4000AWW - pump removal?
I found a screw stuck in mine once. Went to all the trouble to take it out and all apart like you're wanting to do. Then I figured out that if I had just took the flexible line off that feeds it from the tub, I could have pulled the screw out with a magnet. Whatever is in yours may be accessible the same way. If the object is non-magnetic you might use a forcreps or needlenose pliers.
