I REPLACED MY INK CARTIAGES YESTERDAY TODAY I GOT A PAPER JAM AND NOW MY PRINTER WILL DO NOTHING BUT MAKE A TERRIBLE NOISE AND GIVE ME A ERROR CODE 0xc05d1281 MY PRINTER IS A HP C8180 PLEASE HELP ME I CAN'T AFFORD TO PAY SOMEONE TO FIX IT FOR ME
First, be certain there are no tiny pieces of paper in your printer, left from the paper jam.
Then, you need to reset your printer - try:
1. Unplug from the power cord.
2. Wait 30
seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more
times.
5. On the third time after plugging the unit into power check the
functionality.
And, if the above doesn't fix:
1. Unplug the power cord from the back.
2. Wait for the
unit to go to the sleep mode. Wait for 60 seconds.
3. Press and hold Print
Photos & Photo Fix
buttons simultaneously on the control panel; keep them
pressed and reconnect the power cord.
4. Continue pressing
the buttons until the display goes blank or Reset shows on the control panel
display.
Good luck.
Friends the answer is you have to open the machine on the left side Beran two small SEEDPODS placed in a metal PIESA jalen acia it a bit carefully you happens to be a manufacturing problem that is solved Beran na not have to do with all those madmen steps tend to those skilled in this forum does not give the correct answer I doubt not know and I do not think turning off the machine fence to solve a mechanical problem my email is [email protected] any other machine I can help comment no matter which model my name is stephan quintero
I found a "roulette blanche de 7-8 mm) in the printer; what should I do with this thing?
