Question about Dryers
Troubleshooting a problem with high pitched squeaking in GE dryer model PBVH520EJ0WW Squeaks when load is small or nearly dry - repairman came to check it out and said he 'couldn't fi
Squeak noticeably more now that the dryer is over 3 years old and gets lots of use. Has a change in pitch as the drum turns, which repeats over and over.
    Habit-Forming:
    New Friend:
  • 51 Answers
Could be the bearings going, other possibilities could be that the drum is slightly misaligned and scraping against the housing, although that's not very likely, or a bad belt.
Although sometimes it's some obscure thing, I could be compleatly wrong.
Posted on Oct 01, 2014
6ya staff
SOURCE:
Donni Steen
  • 687 Answers
SOURCE: Squeaks FSE446RHS2 XD41513722
You can generally access the unit from the rear panel. Try and lube the joints around the pully for the belt and any other moving parts. Hopefully you won't have to replace any parts. Good luck
Posted on Apr 11, 2009
Anonymous
  • 61 Answers
SOURCE: High Pitched Squeak from Maytag Dryer
rpllers or tub bearing
Posted on Sep 29, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: dryer squeals when i turn on
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 01, 2009
Testimonial: "very through info. thank you"
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: High-pitched squeaking during operation
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers may be in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on May 27, 2010
lorri jenkis
SOURCE: GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Posted on Oct 06, 2012
My dryer GE Electric dryer model DBSR453EBOWW squeaks !!
It could be the drum bearing.You prob need to re-grease it.but it could be a devil to get at.
Jun 22, 2012 | GE DBSR453EBWW Electric Dryer
High pitch squeaking noise throughout the whole drying cycle, getting worse.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 03, 2011 | Magic Chef CYG2000AWW Gas Dryer
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 12, 2011 | GE DBXR463EBWW Electric Dryer
My dryer makes a horrible high pitch squeaking sound when it is in the dry cycle. It is about 11 years old. GE profile front load.
heatman101
Jan 05, 2011 | GE Dryers
Our front loading GE dryer is making a high pitch squeaking noise while operating...
heatman101
Dec 16, 2010 | GE DBVH512EFWW Dryer
Dryer squeals and squeaks with full load to be dried
heatman101
Sep 08, 2010 | GE Dryers
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
Dryer squeaks when drying clothes
try letting the mouse out??? its likley to be the drive belt or rear bearing dry,,, could be the motor bearings dry,,
back bearing and motor bearings could be lubed with WD40 but dont put it any were near the drive belts as they will then slip like mad,
spray on the driv belt a bit of "stop squeak" its for car fan belts realy but it works on any rubber belt
Oct 24, 2009 | GE DRSR483ED Electric Dryer
The dryer has started to make a slight squeaking noise, but it is still drying
On a GE dryer the part that squeaks most is a WE3X75. Centerpost drum bearing. It is a simple repair but you must get into the machine.On a frigidaire model The plastic bearing that mounts in the rear sorta like a GE model. No other dryers that I can recall have the squeaks. The newer GE dryers are made very simular to the old reliable frigidaire models so you ought to hit it out the ball park with these 2 links.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 09, 2009 | Dryers
Scraping/high pitched noise in GE model DCVH515GFOWW.
heatman101
sfdyjsdf
Mar 03, 2009 | GE DCVH515GF Gas Dryer
Dryers Logo
111 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
