If your Samsung glass screen is cracked, well there is no any solution without get repaired, So you may visit Smart Repair where smart repair provides end to end mobile repair solutions to customer without any spending much more time. To know more visit at https://smartrepair.io/
Aug 23, 2015 - If you want to sell or give away your Samsung Galaxy Note 5, or if you're ... The hard reset will wipe all files off of the internal memory, as well as ... your phone and just perform a factory reset as a way to make it their own. ... November 7, 2015 at 3:44 pm ... I have problem with my Samsung Galaxy tab 2 ...
? 6:01
https://www.youtube.com/watch?v=7sbgN0PxMzc
May 2, 2013 - Uploaded by HARD RESET KING
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0Android 4.0 ... hi I got the same one as you and ...
If you cannot do a reset of the internal fuse system and get it operational, then check the internal battery for continuity. If they all fail, then the AC/DC transformer has blowen.
You can first attempt to do a "soft reboot" by pulling the battery at the same time as the screen is flashing the logo as you stated. (Pulling the battery IE:remove battery with phone in 'ON' state)
If this does not solve your problem, a "hard reboot" might be your only other option, (short of bringing it into to a service center location for your cellular provider or sending it into to a service center via postal delivery).
To perform a hard reboot on the Samsung Galaxy Pro please follow the proceeding steps as they are listed:
Press & Hold The "Power/Lock Key" & "T/3" Key Of The Qwerty Keyboard At The Same Time Until The "Android system recovery " Menu Shows Up.
Use The "Volume Key" To Scroll Down & Select "wipe data/factory reset".
Press The "Home Key" To Proceed To The Next Confirmation Step.
Use The "Volume Key" Again To Scroll Down 7 Times & Select "Yes - delete all user data".
Press The "Home Key" To Perform Hard Reset. After 2 Or 3 Seconds It Will Show Data wipe Complete.
All User Data Will Be Removed And The Device Will Be Restored To Manufacture Default.
Press The "Home Key" To Reboot System Now.
SAMSUNG GT-I9000 GALAXY S [ HARD RESET ] FORMAT FORGETTON PATTREN SOLUTION [ TESTED ]
[1] Take out & Insert battery press & Hold VOLUME up+ Home Button Keep Power Button Pressed for 4 Seconds[important] Still KEEP Volume up & Home Button Pressed
[2] Phone will Start In RECOVERY MODE scroll down using volume down button to " wipe data/factory reset" [3] press Home button to select now scroll to "yes Delete All user Data" to confirm [4] press Home Button. Your are Done.
[IMPORTANT] Make sure you will loose all data Saved on phone memory like photos & Phone book videos ETC.
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Astatic - 4 wire
1- Shield
2- White
3- Red
4- Black
static - 6 wire
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S - 4 wire
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner RK56 Road King
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Regards,
Tony
