I know it's an older model - 2000/2001 - I'm trying to determine if it's worth trying to fix.
SOURCE: PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
Hey zrscott388, did you end up replacing the bulb and did that fix it? My Z1 is doing the same thing. I hate to spend 300-400 on a bulb and it doesn't work. The Z5 is going for 1100 new on Ebay. I rather do that than waste money. Please let me know.
SOURCE: projectors
HI there
Check that your power cable is ok. Best way is by trying a differnt cable. If the problem still shows , you might have to open it up check if the fuse on the powersupply board is ok and then worst case cenario have the powersupply replaced.
Hope this is of help !
SOURCE: power light blinking red
if the lamp goes out after the red led goes on, there is a fan issue and the projector is overheating or the ballast/power supply can't hold the voltage.
