Model: 79045482501 serial number:NF61307697
Sounds like you got an electrical short. Pull out the range, unplug it, and then check the electrical connections where the wires go into the range. If that's okay, then check the oven bake & broil elements. Also check the electrical connections to those elements. I'll bet you'll find one that shorted to the back of the oven.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
SOURCE: Error code E1 -F5- Broil element comes on and wont shut off
I just did the self clean option and when it was done I received the error code E1 -F5- and it does have to do with the door latch. After turning off the power to the stove I was able to open the door and wiggled the latch and that solved the problem.......
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
SOURCE: Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
SOURCE: no power to stove after turning on oven and hearing a loud ''POP''
I called the Sears repair man.
SOURCE: My Kenmore gas stove model 790, the oven will not
It appears your thermostat/probe has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
