Sony BRAVIA KDL-46W4100 46 in. LCD HDTV Logo
A
Anonymous Posted on Sep 30, 2014
HOW DO I ADJUST MY TV DIGITAL AUDIO OUTPUT WHEN USING THE TOSLINK CABLE?
CONNECTING A OTICON CONNECTLINE HEARING DEVICE USING DIGITAL AUDIO VIA THE TOSLINK CABLE
2 Related Answers
Anonymous
  • 81 Answers
  • Posted on Apr 08, 2008
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Anonymous
  • 98 Answers
  • Posted on Mar 19, 2009
SOURCE: sony bravia klv-32t400a hdmi input through x-box
The problem is that, according to the specs for that TV, it doesn't support 1080p.
That's a 720p television you've got. (Specs here)
While the specs say that it supports 1080p, the resolution says it supports 1366 x 768, which is only 720p, not 1080p or even 1080i.
You may want to contact Sony for clarification, because their specs for that tv are contradicting each other.
Hello i bought a sound bar its a phillips cant get any sound out of it tried another tv same thing
Most sound bars are connected from the TV via the audio output. Try connecting out from tv with Toslink or optical cable. This should operate all of your tv audio.
I need some help hooking up an amp, tv, and xbox 360 together please! I have a Toshiba 46g310u TV and Xbox 360 already hooked up together using an HDMI cable. I just bought a Yamaha R-S300 amplifier,...
Many TVs have to have the optical output enabled in a set-up menu. Do you see red when the connector is disconnected (which doesn't necessarily mean that it is active, just that it is 'ON').
Have you checked the amplifier to insure that the input is working by connecting something else directly up to it? Can you test the TOSLINK converter by plugging the output into something else to determine where the problem lies. I still suspect it is in the menus of the TV.
1helpful
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
1helpful
PC Sound Card Connection to Denon AVR-2805 or Samsung 40B610
  • Should I be connecting my pc sound card directly to the receiver or to the tv then to my receiver to get the best sound output? To your reciver
  • When I get the HD Digital Tuner, does that make any difference for the pc connection?
  • Try to connect everything that is sound onto your reciver then
  • connect all your video to your your TV for now
  • When you get your digital tuner connect all your inputs for video to(in order >reciever>HD Tuner>TV
  • Basicly everything goes to your tuner first.
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
I need a diagram of how to hook up my jvc 5.1 surround sound to my tv, dvd and cable box
I my self don't have that exact unit, but most are similar, and i have looked up the specifications which are:
Inputs:
1 x S-video input
1 x Composite Video Inputs
1 x Digital Audio (TOSLINK) Input
1 x Stereo Audio Input
Outputs:
document.write(neg_specification_newline('1 x S-Video Output
1 x HDMI Output')1 x S-Video Output
1 x HDMI Output
INPUTS (coming from devices to the system):
1) The unit already comes with a DVD player, correct? If so you don't need to connect it. If you do, connect your DVD play via an s-video input, since a normal DVD player doesn't need a higher quality/resolution input.
2) Connect your cable box to the home theater system via a composite cable (the one with Red green blue), if it has composite outputs ofcourse. If not, do it visa versa with the DVD, if your dvd has composite. So make the dvd via composite and cable box via s-video.
3) Audio from the dvd, this would be via Digital Audio (TOSLINK) Input or stereo audio input. the digial audio will give you true 5.1 surround sound, and the stereo will only give you left and right channels, like you would hear from anything else (like a normal cd, radio, etc).
4) audio from cable box, would be again depending what you want. If you cable provider gives you alot of programming that has 5.1 surround sound (mostly HD channels), you would be better off with the digital audio. But if you watch more via your DVD, then connect the cable box via the stereo input. Again, this is to your preference, and which one you want true 5.1 surround sound from. The system should be able to 'emulate' 5.1 surround sound via the stereo cable too, but if your watching a movie, it can't really tell if a sound is supposed to come from the left rear or the left front.
Output:
5)connect to tv via HDMI if available, or S-video.
HDMI is much higher resolution (HD quality) S-video is normal cable programing or 'dvd quality'.
And the Tv would be left on mute or volume=0 since no audio is connected to the tv! All the audio should now come from your system.
Sorry if this was too vauge, but I don't have the same system and dont know exactly what/where all the connections are. If you have any other questions let me know.
No Dolby Digital through DVD player
Have you configured the digital output settings on the DVD player? You may need to set the digital output format in the DVD player setup menu. If it is set for LPCM then you won't get sound. It has to be set for bitstream and yoou may need to tell the player what output to use.
As you didn't mention the brand of DVD player, I can't really give you any detailed instructions.
Also try using the optical cable that you have connected to the cable box to test it and see if you get any output on that connector. If yyou do then it is a setting in the amp that is not configured properly,
Best of luck
Cheers
2answers
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
