Replaced Lamp about 3monts ago. Clean both fans they were very dusty
SOURCE: Red lamp lite flashes along with power light.......
That is definitely the Light Engine (also referred to as an optical block) Very expensive.
SOURCE: Sony Grand vega 55" will blink green for three times than red
Your problem is your thermal fuse.It is located around the bottom of the compartment that houses the lamp. You will have to remove the lamp and take the bottom back panel off. Then you will have to remove the fan. I ordered the thermal fuse so I would know what I was looking for when I started to replace it. If you take your time and are patient enough you can fix it yourself. I fixed mine and it's working great.GOOD LUCK!!!
SOURCE: had continous red blinks on lamp led replaced lamp
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
