Linksys WRT160N Wireless Router  Logo
A
Anonymous Posted on Sep 29, 2014
Just got new router cannot connect to internet
Running windows 8 on all three computers
L Pfaff
Level 3:
Top Expert:
  • Linksys Master 11,573 Answers
  • Posted on Jun 30, 2016
L Pfaff
Linksys Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587131
Points
181713
Linksys WRT160N Wireless Router installation
Prashant M
Level 3:
  • Linksys Master 2,278 Answers
  • Posted on Nov 24, 2014
Prashant M
Linksys Master
Level 3:
Answers
2278
Questions
Helped
978461
Points
6246
You have WRT160N wireless router.
You can install this router without using installation CD.
Connect the modem to the Internet port on the router. Connect one computer to the port 1 on the router.
Reset the router.
Open the setup page of the router and change the settings manually.
Check the link for WRT160N router setup without CD
5 Related Answers
Anonymous
  • 9 Answers
  • Posted on May 01, 2009
SOURCE: Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Anonymous
  • 12 Answers
  • Posted on Jul 01, 2009
SOURCE: No internet through router
There is a section in the router that says Status. In order to get to the router webpage, choose your start button and then choose Run. From there you want to type in the letters:
cmd
and then press the OK button
When the DOS like box opens, type in
ipconfig /all
Notice the line that gives you the Default Gateway, should have something like:
192.168.1.1
at the end of it.
Whatever the number is, mark it down. Connect your laptop or pc to the router. Pull up the 'web' and then try to visit the Default Gateway ip address instead of a website:
http://192.168.1.1
if it asks you for a user name and password, choose the password field and type in
admin
hit the keyboard enter key and see if you can get into the router web page. If you can, then check the status section and see if you have WAN or Internet connection to Comcast or Cox or whatever your internet provider is... it should NOT say 0.0.0.0
If it does, then you want to make certain that the cable from the MODEM to the Linksys router is going directly into the router's Internet or WAN port. If this is the case, consider using another cable. If that does not work, you may be better off buying a replacement router. I have always had luck with a Netgear wgr614. It does not give you the fastest, but faster speed routers often requires unrealistic upgrades, and it not necessary for daily use if this Linksys router has worked well enough for you in the past.
Additionally, know that these routers are sensitive to power surges and a SURGE PROTECTOR, not a power strip, may be the smartest investment you can have for both your pc and your modem / router.
Anonymous
  • 218 Answers
  • Posted on Jan 03, 2010
SOURCE: 3 failed attempts to connect HP DV6t laptop
Check this Linksys FAQ website:
http://www.linksysbycisco.com/US/en/support/WRT310N
govinda123
Prashant M
  • 2278 Answers
  • Posted on Apr 20, 2010
SOURCE: my laptop running window 7 64 bit connects to
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Anonymous
  • 550 Answers
  • Posted on Apr 27, 2010
SOURCE: No internet connection when router is connected
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
WNDR3400 windows 8
Possibly. There are things that needs improvement for Windows 8 synchronizing with other devices.
How do i connect my new computer to a linksys model wrt54g? I have a new hp Pavilion g computer with windows 7
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
Subject: Instructions for connecting to a router
Customer's exact description: how do i connect my new computer to a linksys model wrt54g? I have a new hp Pavilion g computer with windows 7
Discussion: Tjhanks for letting me know that you are running Windows 7. Most people never mention the OS. This will be a three (3) phase solution. It is imperative that each step be followed in order.
First Step: Let's make certain that your operating system is ready to accept your router. Click on the following link and Microsoft will analyze your system and correct any deficiencies. Microsoft Fixit Site.
Second Step: Make certain that your router is up-to-date.
Updates are regularly posted on the manufacturer's site to fix issues you encountered while attempting to use their device. The following will guide you on how to keep your device updated and working properly.
These are the common reasons why you need to do an upgrade:
• Dropping or intermittent connection • Fix the bugs and known issues with the current firmware or driver version • Basic Troubleshooting did not work
NOTE: For basic troubleshooting tips in wirelessly connecting to your router, please refer to your user manual.
Firmware updates are required especially if you start experiencing connection problems within your local network. An updated firmware also fixes the bugs of its previous version as well as providing new functionalities for the device. However, this should only be done after doing some basic troubleshooting that did not work.
There's and easy way to check on outdated firmware, drivers and software. Just click on the following link and download a small program named SlimDrivesr Free: CLICK HERE
NOTE: Updating the router's firmware is not recommended if there are no connectivity issues.
Adapters
A driver update for your adapter is necessary in order to enhance the wireless performance and functionality of your device. This is recommended especially if the adapter is not working properly after you updated the router or the computer itself. A corrupted driver will cause your adapter to stop working.
QUICK TIP: For both Ethernet and wireless adapters, you need to download drivers, while for devices such as routers, gateways and network access storage, you need to download the firmware.
Third Step: Connecting to the Internet using a Router
Choose a convenient location to begin installing your router, such as an open floor space or table. This does not need to be the permanent location of the router. For wireless routers, it may be necessary to re-position the unit after installing it as the signals may not reach all areas needed.
• Unplug the power to your Internet modem. • Power down your computer(s). • Plug the power in to your router. • Connect your Internet modem to the router. The cable plugs into the router jack named "WAN" or "Internet". Turn on your Modem. • Connect one computer to the router. Even if the router is a wireless model, connect this first computer to the router via a network cable. • Turn on the computer. • From the computer connected to the router, open your web browser. Enter the router's address, http://192.168.2.1, and press Enter on your keyboard. • Click Login. The router does not ship with a password, so just click Submit. To configure the router to connect to the Internet, you must enter information provided by your Internet Service Provider (ISP) into the "Connection Type" section in the left-hand column under the "Internet WAN" heading of the router's configuration page. If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider, the static IP fields (including network mask and gateway) must also must be set in the router.
Since this is a wireless router, change the network name (referred to as SSID). While the router comes to you with a network name set at the factory, you may want to use something more familiar for your network. Read Changing the Router's Wireless Channel and SSID -- or some other similiar language in your user guide --for a description of this process.
Verify that this computer can connect to the Internet properly. Open a new web browser and visit a few Internet sites such as Google.com or Yahoo.com.
Finally, configure additional network security features as desired to guard your systems against Internet attackers.
That's the three step program to solve this particular problem.
If you are still having problems, follow the steps outlined in the Windows operating instructions. Unfortunately, most individuals buy computers with the software installed by the manufacturer and don't receive the full manual.
1. Open Internet Explorer 2. Click on TOOLS 3. Click on INTERNET OPTIONS 4. Click on CONNECTIONS 5. Click on SETUP 6. Click on I WANT TO SET UP MY INTERNET CONNECTION MANUALLY 7. Click on NEXT 8. Click on I CONNECT THROUGH A LOCAL AREA NETWORK (LAN) 9. Click on NEXT 10. Click on NEXT [this is not a typo] 11. Click on TO CONNECT TO THE INTERNET IMMEDIATELY .........; and, 12. Click on FINISH
You should now be connected.
All the best,
Ben
I have a belkin f5d8636a.4 wireless router and need to connect it to a new computer running windows 7 using a belkin f5d8053uk usb stick. i need to know are both these items windows 7 compatable or do i...
The Router supports a variety of networking environments including Mac OS® 8.x, 9.x, X v10.x, Linux®, Windows® 98, Me, NT®, 2000, XP, and Vista®
usb stick OS Compatibility: Windows® 2000, Windows® XP 32 bit, Windows Vista® 32 bit
My wireless internet stopped working. i have model #wrt54g v8. i have cable internet also. when the wireless stopped working cable company checked said everything on there part is fine. its pluged in. the...
When you plug in the ethernet cable the corresponding numbered indicator on the router should flash to indicate a LAN connection and some data flow from the router to the computer. This does not necessarily mean that there is data flow from the internet to your computer via the router. Simple check would be to use a smartphone and try and connect to WiFi on the router but restart the router first. If the smartphone is also having problems then the problem may be with your internet provider or the router. If the smartphone connects then restart the computer. If the computer still does not connect then try the following steps to refresh the computers IP address:
For Windows XP
Step 1
Click Start->Run, type cmd and press Enter.
Step 2
Type ipconfig /release at the prompt window, press Enter, it will release the current IP configuration.
Step 3
Type ipconfig /renew at the prompt window, press Enter, wait for a while, the DHCP server will assign a new IP address for your computer.
For Windows Vista& Windows 7
Step 1
Click Start on the task bar, type cmd into the search box and press Enter.
Step 2
Step 3
Type ipconfig /renew at the prompt window, wait for a while, the DHCP server will assign a new IP address for your computer.
For Windows 8 & Windows 8.1&10
Step 1
Press windows key and X key at the same time. Then click at Command Prompt.
Step 2
Type ipconfig /release at the Command Prompt window, press Enter, it will release the current IP configuration.
Step 3
Type ipconfig /renew at the Command Prompt window, wait for a while, the DHCP server will assign a new IP address for your computer.
Hope that helps.
https://fastproactiveit.com/
Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
I don't have wireless internet access. I have internet on my desktop computer with my Linksys WRT110 router connected. I lost connection this morning while online. The network doesn't show up on the...
Turn the router off.
Count to thirteen.
Turn the router on.
In Windows, click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG /RENEW
Press Enter
Try again to access the Internet.
2nd computer not connecting to internet
i m using this router
and problem i m occuring is that..i can only run one thing at time
i m using iphone ma laptop and e63
when iphone is using it...other things do get connected but dun get internet access
when i use e63 it gies an error of no gateway reply after it gets connected to router
plz help me that how can i run three things at one time without getting disconnection
Hi, i need help with my IE8
I suspect your internet connection.
Can you get email?
Are you sure you're on the net?
One thing to do in this case would be to unplug the modem and router (if you have one) and turn off the computer. Then plug in the modem, router, and start the computer.
Just to see if you are on the internet, from start, click run and type cmd in the box or, in Vista and Win 6, just type cmd above the start button.
When you get the black window, type ipconfig. This should show you your IP address, the subnet maks, and the default gateway. If all three are not shown, you are not connected to the modem or router.
If all three are there, type ping www.yahoo.com (or any other site).
You should get 3 returns. If not, you are not on the internet. I would then suspect that your username and password are not being passed to the ISP. Fix that and you're OK
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter 192.168.0.1 in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Setting up Comcast High Speed Internet with a Linksys Router
The following article will describe how to setup Comcast High Speed Internet with a Linksys Router: Connecting your cable modem to the Router 1. First connect directly to your Cable modem without the router and verify that you can get on line. 2. Once you've verified that you can get onto the internet without the router please proceed. If you can not please contact your ISP for further assistance. 3. Now unplug the Ethernet cable that connects to your DSL modem from the back of your computer. 4. Take the connection that you just unplugged from the back of your computer and connect it to the WAN port of the router. 5. Take a different Ethernet cable and plug it into port closest to the WAN port, or into the LAN port. 6. Look on the front of the router. The following lights should be illuminated: - Power - WAN Link - Link/Act (On the port that you connected your computer to) - Note If other lights other than Link/Act are illuminated on this port, that is normal - You may have a few other lights illuminated depending on the model number router you have, but the 3 above must be illuminated for proper connection. 7. Hold the Reset button on the router for 30 seconds or more 8. Restart your computer Checking the MAC address of your Computer Please follow these steps from the computer that was connected directly to the internet with out the router. If you do not, then you may not be able to connect to the internet properly. A. Windows 9x/ME 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in winipcfg and click the OK button 3. When the "IP Configuration comes up" click on the gray box the black arrow and select your Ethernet card. 4. Please make note of the "Adapter Address" B. Windows 2000/NT/XP 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in cmd and click the OK button 3. When "Command Prompt" appears type in ipconfig /all 4. Please make note of the "Physical Address" Configuring the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP). 2. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go. 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. By default the router will be set to Obtain an IP Address Automatically. 6. Click on the Advanced tab. 7. Click on the Mac Addr. Clone. 8. When the page loads, input the Adapter/Physical Address you made earlier and input it into the proper fields. 9. Click Apply Finishing the Setup 1. Shut down your PC. 2. Unplug the power from the back of the router. 3. Unplug the power from the modem. 4. Wait for 30 second. 5. Power up the modem. 6. Wait for the lights to stop blinking. 7. Power up the router. 8. Start up your computer. 9. Surf the internet. - *Note: If you are still unable to get on to the internet please repeat from step 1.
The following article will describe how to setup Comcast High Speed Internet with a Linksys Router: Connecting your cable modem to the Router 1. First connect directly to your Cable modem without the router and verify that you can get on line. 2. Once you've verified that you can get onto the internet without the router please proceed. If you can not please contact your ISP for further assistance. 3. Now unplug the Ethernet cable that connects to your DSL modem from the back of your computer. 4. Take the connection that you just unplugged from the back of your computer and connect it to the WAN port of the router. 5. Take a different Ethernet cable and plug it into port closest to the WAN port, or into the LAN port. 6. Look on the front of the router. The following lights should be illuminated: - Power - WAN Link - Link/Act (On the port that you connected your computer to) - Note If other lights other than Link/Act are illuminated on this port, that is normal - You may have a few other lights illuminated depending on the model number router you have, but the 3 above must be illuminated for proper connection. 7. Hold the Reset button on the router for 30 seconds or more 8. Restart your computer Checking the MAC address of your Computer Please follow these steps from the computer that was connected directly to the internet with out the router. If you do not, then you may not be able to connect to the internet properly. A. Windows 9x/ME 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in winipcfg and click the OK button 3. When the "IP Configuration comes up" click on the gray box the black arrow and select your Ethernet card. 4. Please make note of the "Adapter Address" B. Windows 2000/NT/XP 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in cmd and click the OK button 3. When "Command Prompt" appears type in ipconfig /all 4. Please make note of the "Physical Address" Configuring the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP). 2. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go. 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. By default the router will be set to Obtain an IP Address Automatically. 6. Click on the Advanced tab. 7. Click on the Mac Addr. Clone. 8. When the page loads, input the Adapter/Physical Address you made earlier and input it into the proper fields. 9. Click Apply Finishing the Setup 1. Shut down your PC. 2. Unplug the power from the back of the router. 3. Unplug the power from the modem. 4. Wait for 30 second. 5. Power up the modem. 6. Wait for the lights to stop blinking. 7. Power up the router. 8. Start up your computer. 9. Surf the internet. *Note: If you are still unable to get on to the internet please repeat from step 1.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
