The switch works, the motor works, but circuit can't go through the circuit board. Where do I find parts to fix it or purchases a replacement board? I called Rotozip and was told no replacement available. Do you think I could wire the switch directly to the motor? It would only be one speed then.
SOURCE: i need rotozip bit change instructions
Press in shaft lock button, use supplied open-end wrench to loosen collet--RH thread and remove bit by hand.
SOURCE: I have a rotozip - RZ20. I've been using it
Your speed controller has failed. You will need to get it replaced, brushes do not give, those symptoms.
SOURCE: I purchased a demo model of the RotoZip 10 from my
Hi, W/D here.
Check the brushes first. Demo's get pilfered for small items, and the brushes may have been 'misplaced'. If they're there, then trace your wiring through the switch.
Best regards, --W/D--
SOURCE: Trying to get blade off
Try a little PB blaster penetrating oil and a little more muscle not to much!! Nut might be a tad bit rusted in place. Good Luck....
SOURCE: rotozip lock wont release
You may have to split the housing for this. I have seen where the pin can become bent or where the plastic housing becomes worn at the pin and allows it to move around too much. They usually also have a small spring with the pin which may have failed.
