Question about Dell 1210S Projector
How do I know if I need a new light bulb for my projector?
The light bulb button is blinking.
Lamp cut off, power light(green) flashing, ready light (orange) off
deffo the bulb life. not a cheap fix as bulbs are very expensive. reset the unit by holding a few buttons.mine resets by holding 2 buttons while off. google master reset for your model and you might get some more user time from the bulb. change bulb asap tho
Mar 08, 2014 | Dukane ImagePro 8039B LCD Projector...
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Infocus IN72 - blinking RED light
firdt off, did you reset the lamp counter? did you clean the dust out of the projector? it may be overheating as well. if the lamp looks ok, you may have just blown the ballast. try projector doctor online.
Mar 03, 2010 | InFocus IN72 Multimedia Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
No light projects.
Try resetting the projector by pressing and hold the two Keystone buttons, then turn ON projector. Hold down the two Keystone buttons for 15 seconds, then turn OFF projector.
Turn ON projector, the new lamp should strike.
Mar 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Oct 28, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Bulb failures
I experienced the same thing, only to discover it was the ballast that powers the lamp. I believe INFOCUS repairs for $390.00 per the technician that I spoke with on the phone at INFOCUS.
Jun 29, 2008 | InFocus IN72 Multimedia Projector
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Dell 1210S Projector Logo
108 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Richard C Cohen
Richard C Cohen
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
