I am trying to figure out how to reprogram the code on my craftsman keyless entry pad model number 139.53876.Does anyone have a clue
I am not sure how to upload a file on here but I have the instructions for programming the key pad. if you would like a copy let me know!!
Here is a link from sears but you have to register your e-mail address to view it - no major thing!
Hope this helps!
http://www.managemyhome.com/mmh/products/ManualSearch.action?sid=MMHMxSearsx00019&product.modelNumber=13953684&product.brandName=CRAFTSMAN
Hope this helps!
http://www.managemyhome.com/mmh/products...
Solution #1 worked excellent. Thanks. Fixed the problem with the key pad in 35 seconds.
Yes worked once I remembered to hold for 5 sec.
Found the solution for programming keypad:
http://www.chamberlain-diy.com/diy04/pdf/programming_instructions/940CB.pdf
SOURCE: sears keyless pad
hello - we have a craftsman model 139.53684 and these are the instructions for setting the personal entry code - (you will need two people doing this) To set the code using the Premium control console: 1 Enter a four digit personal ID # of your choice on the keypad then press and hold ENTER. 2 While holding the ENTER button, press and hold the LIGHT button on the premium control console (the premium control console is the main opener button mounted in the garage probably near your door) 3 Continue holding the ENTER and LIGHT buttons while you press the pushbar on the premium control console (now all theses buttons are held) 4 When the motor units lights blink Release buttons - it has learned the new code. If bulbs are not installed you will hear two clicks. To set the code using the 'LEARN' button (you will need a ladder & two people doing this) you used the learn button to set the new remote. 1 press and release the learn button on the motor. The learn indicator light will glow steadily for 30 seconds 2 within 30 seconds enter a four digit personal ID number of your choice ob the keypad then press and hold the ENTER button 3 Release the button when the motor unit lights blink If bulbs are not installed you will hear two clicks. I hope this fixes your problem - please post & let me know - thanks Sam
1. Press and release the learn button on the motor. The learn
2. Within 30 seconds enter a four digit personal ID number of your
3. Release the button when the motor unit lights blink If bulbs are not
Trying to program a second remote. I found an old remote I had for another house. I set the codes inside the remote to match my existing one, now my original one will not work.
cannot reprogram my key pad? how do i do it?
139.53684 keyless battery operated entry. I have new batteries in this and both of my remotes. I can only program 1 remote at a time and cannot reprogram keyless at all. I have tried red button resets on all per manual, with no results. E-mail help to [email protected]
how do we program the wireless remote
Having same problems. Able to reprogram remotes but not key pad. How do I set up and program keypad to work with garage door. Also need to know how to reset pass code on keypad.
I'm also trying to figure out how to reprogram my keypad. Model 139.53876
WANT TO RECODE THE KEYPAD FOR GARAGE DOOR
I recently programmed my car's remote garage door access and now my wireless keypad doesn't work. I can't find my instructions; it is several years old. (Sears Craftsman Model 139.53876) Can anyone help? Thanks so much!
I have the same issue. I bought the house with the remote and garage door opener installed and according to the previous owner "a lot" of people know the access code. No instruction manual, just need to know how to reprogram the code.
Having same problem, just purchase house and need to rekey the pad. remote opener works fine. Help!
need to reprogram my remotes just moved in
the keyless remote stopped working, I replaced battery and nothing happened. How do I reprogram it?
Trying to reprogram remote opener
I need to reprogram my keyless entry pad. I have a Craftsman 139.53645SRT. I can't find any information on this in the manual.
Help!
We have a keyless pad that we've used with a 1/2 HP opener for years with no problem. We've had one handheld opener in one of our cars and the other has a programmable feature built into the driver side visor that remotely opens the garage door. We just purchased a second vehicle with that same feature and programmed it, but found that the keyless pad can no longer be programmed. We've changed the battery in the keyless pad and are still unable to program it. Is it possible to have two vehicles programmed with the installed opener feature and also use a keyless pad?
I have the remote wireless number keypad and have moved to a new home and need to know how to reprogram it for the new door opener.
I need the programming steps including which button to push on the remote to link it to the door operator.
pls advise.
thanks,
how do you reprogram keyless pad for craftsman garage door opener if you do not have a code
Having same problem, just purchase house and need to rekey the pad. One remote opener works fine the other two don't seem to work.
BOUGHT ANEW GARAGE DOOR OPENER CRAFTSMAN 53930 MY KEYLESS 139.53684 WON'T WORK WITH IT
my neighboor down the road's remote controler is opening and closing my garage door. How can I get rid of this problem?
I have a similiar problem. My old garage door broke and I cannot get this keypad to work with the new door.
