Question about Emerson EWR20V5 DVD Recorder/VHS VCR Combo - Salvage/Replacement Parts Only
DVD-RW disc will not record. Never have been able to record. What is wrong?
6ya staff
SOURCE:
Anonymous
SOURCE: Emerson DVD Recorder EWR20V
The problem is likely that you are using 8x/2x media. Though the booklet does not say it, the burner does not support anything above 4x for DVD-R and 1x for DVD-RW. Calling their tech support can (possibly) get an update for this problem. Otherwise, the burner cannot use anything but outdated media.
Posted on Jun 02, 2007
Anonymous
SOURCE: dvd recorder won't record on DVD-RW disc.
CLEANING THE DISC LENS ? If this unit still does not perform properly although you refer to the relevant sections and to ?TROUBLESHOOTING GUIDE? in this Owner?s Manual, the laser optical pickup unit may be dirty. Consult your dealer or an Authorized Service Center for inspection and cleaning of the laser optical pickup unit. FROM EWR20V5 OWNERS MANUAL FUNAI-CORP.COM
Posted on Jul 01, 2007
Anonymous
SOURCE: cannot record on DVD-RW disc
I CHANGE DISK 4 TIMES WITH THE SAME RESULT
Posted on Dec 23, 2008
Anonymous
SOURCE: Recording Error -- E7
When I bought my emerson ewr10d4 about 2-3 years ago, the machine only recorded on disks that were rated at 2x or 4x speed. And it didn't accept off-brand disks, it only liked the major brands like Maxell, TDK, Memorex, Sony. I learned this quirk the hard way. Eventually, when I called the 1-800 number, they sent me a disk to upgrade the recorder to 8x speed (and it was very simple to do - basically just pop it in). Helped a lot, although this year most disks in stores are 16x speed, and as of a couple months ago (November 2008) emerson didn't have a newer up-to-date upgrade available. But if you didn't do the 8x upgrade yet, call them and start there. It's a small improvement, but an improvement nonetheless. By the way, if anyone wants to buy some lesser-known chinese and japanese-brand disks, I may be able to help!
Posted on Feb 16, 2009
Anonymous
SOURCE: i have anemerson ewr20v4 combo
yes, i just spoke to cs today. For about $20 the are sending me an upgrade to play up to 8x dvd
Posted on Oct 03, 2009
My Philips DVD Recorder does not accept a DVD disc shows no disk. The DVD disc does not revolve. A CD disc revolves but shows junknown
Could be that you are using the wrong type of DVD ? There are two formats DVD+R, DVD+RW etc and DVD-R, DVD-RW etc. Some machines are capable of using either, others can use one of the two formats.
My other suggestion is that some machines are picky about which manufacturer's DVDs they will use.
6.November.2015
https://en.wikipedia.org/wiki/DVD_formats
if you have an error code this might be useful
Dvd recorder won record on DVD RW disc
Some possibly relevant answers here which suggest my answers above
http://www.digitaltvbanter.co.uk/uk-tech-digital-tv-digital/25025-brand-new-panasonic-dvd-recorder.html
Nov 06, 2015 | Philips Televison & Video
Can't record DVD's
Hello there.
As per http://www.videohelp.com/dvdrecorders/cinevision-rv4000/881
you can see that your DVD player only supports writing to DVD+R
or DVD+RW, not DVD-RW or DVD-R.
Hope this helps.
May 24, 2008 | GoVideo Cinevision RV4000
I have a Magnavox MRV700VR. I can record on a DVDR, but when I try to record on a DVDRW it tells me "disc error". Why?
It will be either that you have not formatted the disc or that you are using the wrong type of disc. You will need a DVD+RW on a + machine or DVD-RW on a - machine. Most recorders will playback the other type but not record on it.
Jan 28, 2013 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
Can't record anything....dvr won't recognize blank
Not sure, but could be as simple as switching to a dvd-rw disc. Not all recorders recognize all formats.
Mar 16, 2009 | Televison & Video
How do you use the combo I tried but I did it wrong it says wrong dvd and it is a rewritable one Thamks
The Go Video VR 4940 can only record to DVD -R and DVD -RW discs. It cannot record to +R or +RW discs. It can play back many types of discs, but can only record to the -R and -RW ones.
JFFields
Jan 16, 2009 | GoVideo VR4940 DVD Player/VCR
Dubbing VCR to DVD... it records for 20 seconds then stops
Try a -RW disc. Only the higher priced DVD recorders can use the +RW disc.
Electrode
Mar 15, 2008 | Zenith ZRY-316 Video Recorder
Will not playback get error message Please Check Disc
i have a r136 , have you got the dvd discs u need ? i had the wrong format .
eg, dvd+rw needed dvd-rw
if not and there re-recordables they dont work after a few recordings and u need a new disc.
Dec 05, 2007 | Samsung DVD-R130 DVD Recorder
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Emerson EWR20V5 DVD Recorder/VHS VCR Combo - Salvage/Replacement Parts Only Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
