1996 Geo Metro Logo
A
Anonymous Posted on Sep 28, 2014
Why I have no power on 1996 geo metro fuel pump when I try to star it ?
  • Anonymous Jul 05, 2015
    does it crank ok? robust cranking.
    yes, no/?
Richard Maldonado
Level 2:
Habit-Forming:
  • Expert 65 Answers
  • Posted on Jul 05, 2015
Richard Maldonado
Expert
Level 2:
Habit-Forming:
Answers
65
Questions
0
Helped
98387
Points
185
Testing for 12volts to fuel pump must be done while cranking. If no voltage is present then next step is to check all fuses.. Fuses OK? The next tests will require some basic auto electrical knowledge and if you are not sure I suggest taking your car to a shop. Ready? Fuel pump relay is in relay box near battery once located remove and with a known good 12volt test lamp check 12volts at terminal 1 with key on . OK? Check for 12volts at terminal 4 while cranking . OK? Now with test lamp clip attached to positive terminal probe pin 2 while cranking , test lamp should remain on. If all inputs are OK at relay then relay is bad. Apply 12volts to terminal 3 using a fused jumper wire .vehicle should start. Good luck
I’m happy to assist further over the phone at https://www.6ya.com/expert/richard_9a19ee73dfa4686a
_-__-___-_
Level 3:
  • Geo Master 20,706 Answers
  • Posted on Sep 30, 2014
_-__-___-_
Geo Master
Level 3:
Answers
20706
Questions
Helped
6803550
Points
57965
Sep 28, 2014
too old, to post ...? seems not.
check pump voltage at the pump cranking.
then if that fails to be 11v.
then at the fuel pump relay, cranking, (the big pink wire is it)
FI fuses
and ig-coil fuse must be good.
and the CEL lamp glow key on, or ECU may be dead.(ask)
always test with a $10 volt meter,
voltages matter, test lamps were great back in 1950/60.
these cars love to have, like 6 or 8v on the way to the pump, due to rust on the connectors.
the meter shows this truth, and never a lamp.
5 Related Answers
Anonymous
  • Posted on Aug 23, 2008
SOURCE: how to change water pump in 1996 geo metro?
DITTO ON AUTO ZONE...Don't buy a book, have Auto Zone people copy instructions from their data base for free.
Anonymous
  • 3 Answers
  • Posted on Aug 29, 2008
SOURCE: 1994 Geo Metro sputtered and
have a budy turn the key on but do not try to start you take the gass cap off and lission to see if you hear a whine or buzz for bout 2 sec try turing the key on and a few times if you hear a buzz then the fuel pump is probabley workinf if not then check fuse and relay first also check timing belt
Anonymous
  • Posted on Mar 05, 2009
SOURCE: 1996 Geo Metro 4 cylinder
http://www.fixya.com/cars/t591786-1997_geo_metro_starting_problem
look at this post, this may help, I am having the same problem and am going to try to find one of these parts.
Anonymous
  • 521 Answers
  • Posted on Jul 23, 2009
SOURCE: where is fuel filter located on car? 1990 geo
Below LH Rear Of Vehicle, At LH Front Corner Of Fuel Tank Lh = Left hand Left being driver side of vehicle
Anonymous
  • Posted on Aug 02, 2009
SOURCE: 1994 Geo Metro LSI runs very poorly losing power
Was under the impression that this was a people helping people self help free service / can't afford to pay FixYA !!!
My 1996 Geo Metro stopped and then would turn over but not start what could be the problem
Check to see if you have fuel pressure. Spray some starter fluid into the throttle body. If it starts then check the fuel pump system.
Geo metro 1996
I believe it will since the model of car is not greatly changed over 4 years and the 95 was the first in the revamped Geo series. They mostly just change the body style not the engine parts.
I have 96 geo metro drove 15 miles and just died on me... Will not,start replaced dist. And dist cap and button,coil is getting power fuel is gettin to plugs, tried starter fluid but still nothin, fire is...
Depending on mileage, Geo's have timing belt and it should be changed every 60k, if you've done all that's mentioned I suspect timing belt is broken.
Does a 1996 geo metro have a inertia switch and where is this located thank you [email protected]
no inertia switch on a geo, there is no fuel pump reset at all on the geo.....sorry
Geo Metro 1994, diagnose no fuel presure problem.
Quite a few things can cause a car to die after idling for awhile, but if you have verified that the fuel pressure is actually dropping when the motor dies, the likely culprits are:
1) Electric fuel pump in the gas tank is bad
2) The fuel pressure regulator (on the throttle body) is bad
3) An electrical problem in the power to the fuel pump (like a bad fuel pump relay or lose ground wire to the relay's circuit)
Top Geo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Geo Expert? Answer questions, earn points and help others
