You need to check various issues as to why it is not printing. The issue may be with driver, cartridge, quality of ink or paper or printer settings or any printer software. You may reinstall your driver, use good quality ink and paper, check printer settings and printer software.
You can see setup manual here: http://images.lexmark.com/publications/pdfs/2007/3500/v2103618_en.pdf
Hope it will work. Still facing the issue, you can follow us for Lexmark Printer Support
Have you tried to put;
1. Good cartridges
2. Install the printer's driver on your pc/laptop?
SOURCE: How many copies will the Lexmark Z600 print out?
Specs say 10PPM black and 8PPM color in quick mode.
If you use higher resolution it will be reduced accordingly.
Refer to:
Z600 Series Specs
That is for a Z601, but the 600 should be the same.
Thanks for using Fixya.
