I need the manual for model 1415A
SOURCE: Where can I find a manual for a Remington chainsaw
here is the link. click on it and select the manual to fit your model. http://www.remingtonchainsaw.com/chainsaw.html
SOURCE: Owners Manual for a Remington 2.5 HP 16 '' Chain saw, Model EL-7
Kindly check this link for manual. Please select the correct model:
http://lawnandgarden.owneriq.net/manuals/mfg/remington/remington_chainsaw_product_list.html
SOURCE: oil
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
SOURCE: Remove range cover on remington chainsaw Model LD4018Aw
this web site has partsbreak downs.................http://www.masterparts.net/ hope this hepls,let me know
SOURCE: No manual for Remington electric chainsaw. What oil do I use?
Here is a link to the owner's manual you requested... http://12.153.20.74/manuals/122503-01A.PDF. This one should work for you. According to the manufacturer, Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil. If you have additional questions you may want to contact Master Distributors at 800-446-1446. I hope this helps!
