how do you change batteries on hoveround mpv5 ?
Disconnect cables going from battery boxes to the control box. There is probably a catch that needs to be squeezed in, then pull and wigglt the connection block until it disengages. Release the straps over the battery boxes then remove batteries and covers. Lift up on the cover (you may need to push some cable back into the box) and put cover aside. Disconnect cables from batteries and attach to the new batteries. Same procedure, in reverse, gets you back to an operational MPV5.
