Selonoid has a crack in at on the refrigerator side
SOURCE: refrigerator leaks water
most likely you have a plugged drain int he freezer compartment. if yo will look under and behind the lower basket in your freezer you will most likely see a bunch of ice build up. clear this ice out then you will see a drain hole in the center section behind the metal cover in the rear try to get some hot water into this hole to clear ice and to clear the drain then u shoul be good to go. thanks for using Fix Ya Peyton
SOURCE: Whirlpool Refrigerator(side by side) leaking water
First question would be is your ice machine leaking? If so then disable the ice machine until we can find the cause of leaks and repair them. Is the freezer freezing well? Food compartment temps OK?. Let me know and I will work to help you resolve this. Sea Breeze sea [email protected]
visit my site below
http://servicepartstec.blogspot.com/
SOURCE: my ge refrigerator leaks water
During defrost cycle, the water produced is suppose to drain away through a small drain hole located behind the racks in the freezer section where you'll need to remove the rear panel to see the drain hole. This hole it very likely clogged.
Be careful to unplug the refrigerator before doing any work on it!
SOURCE: My refrigerator leaks water from the inside
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
SOURCE: water leaking from the bottom of my conquest refrigerator
Normal
0
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
