Samsung Galaxy Ace Gt-s5830i - Black Unlocked Smartphone Logo
A
Anonymous Posted on Sep 27, 2014
How do i set my pin number?
Have never set a pin number so the unit is still in the factory default setting - how do i get that?
3 Related Answers
Anonymous
  • 7752 Answers
  • Posted on Jan 12, 2008
SOURCE: samsung E900
do *2767*3855# this will reset the phone for you
Anonymous
  • 22 Answers
  • Posted on Mar 27, 2008
SOURCE: Phone Security setting default factory password
i think it was all zeros. just try
Anonymous
  • Posted on Nov 23, 2010
SOURCE: I have a Samsung Convoy.
menu-messaging-left soft key for settings-entry mode. This will make your text be in letters rather than numbers and then all you need to do is change the letters to numbers in the address of one text and it will continue to be numbers.
I bought mt tv at a pawn shop and want to set it back to factory default. I don't know the pin
there is no way to bypass the pin through settings, the only person that knows the pin is the one who set it. but one way to do it is to pull apart the tv, and find the watch battery or glass fuse that hold the memory for the tvs main board, pull this battery or fuse, and put it back in, and everything should be reset to factory defaults :)
2answers
FIND OUT MY PIN NUMBER
Okay try the usual defaults eg 1111 or 1234 .which service are you trying to access.google the default for that service usually 4 numbers.sometimes 8 if you can't get anywhere contact the provider and get them to email you a reset.
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' [email protected] ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
4helpful
Pin number for goodmans GDB300HD freeview
Follow the following procedure:
1)menu
2)settings
3)first time installation
4)restore system to default
At this stage you will be asked to enter your PIN.Press i on remote
quickly followed by the numbers 4000.The set top box will then turn off
and restart.First time installation can then be completed.
Sir, Model : KENWOOD BT CD/R 3P1 Pronlem : Forgot pin number for connecting a bluetooth device. The pin number cannot be edited/added. It just shows PIN NUMBER in display pannel.
default pin from the factory is "0000" if you have changed it from the default you will have to push the reset button on the unit and it will return to factory presets on all settings.
I installed a security pin number on my brand new Garmin Nuvi 295w and it now will not accept it. How can I reset the 285w to factory default settings?
Restoring it to default factory settings will not remove the pin. This is a safety feature to prevent people who steal them being able to use them. You may still be able to get by it though. There's information on how this may be possible at http://www.fixya.com/support/r6240807-remove_forgotten_pin_from_garmin_nuvi
Jan 30, 2011 • GPS
Forgot pin number
Take the unit back to the exact location the pin was set in. You will then be able to enter the menu to change the pin. There is no other option even by resetting to factory defaults/ Final option is to send it to Garmin
Please rate my help++++Thanks for using FIXYA
Resetting answering machine message, lost instruction manual
goto this wepage put in your model number and you can download your replacement manual.
http://www.doro.com/global/businessunit/dorohome/support/manuals
Reset base unit defaults
Resetting will return most functions to the original factory default setting.
Registrations are not affected by resetting.
1. Press Menu.
2. Scroll using v/V to Base Set. Press OK.
3. Scroll using v/V to Default Set. Press OK.
4. Enter your current base unit PIN code (0000 at default).
5. Press OK to confirm.
2helpful
It ask me enter code. But I lost My security code. Model Number is ZCD-3501AK Make is Zylux Serial No.: HM04040666
Defore starting try default password : 1369
Press the direction keys UP,DOWN to select Default. If Default is selected, press enter key to reset the unit to factory
settings. If you reset this unit, the memorized settings such as Password, Color Settings, Audio Settings will be changed
to Factory Settings.
AFter password getting resetted. try Default password is 1369
Regards
RNJ VINOD KUMAR
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
