Question about DeLonghi DE500P Dehumidifier
Error code e1
Is there anything I can fix? If not, who do I contact.
When I turn on my dehumidifier the symbol E1 appears. Can anybody answer this?
It's not cooling. Unplug it and try to defrost it with a blow dryer. Then, plug it back in and see if the error code goes away. If it doesn't, most likely the coolant has leaked out and you will need to have it fixed and recharged.
Oct 26, 2014 | Danby Dehumidifiers
What does E1 mean on the display of my dehumidifier
follow this steps and fix it. God bless you
E1 error code : Deshumidifier
indicates generally an issue with rh sensor on the back of the control. However, at this time we would like to gather further information relating to the application if possible.
Oct 29, 2013 | Haier DE65EK 65 Pints eco-Friendly...
E-1 error
The E1 error code indicates that the air intake filter needs to be removed and cleaned. Be sure to turn the unit OFF & unplug it before removing the filter. Never operate the unit without the filter in place. Doing so, could damage the unit.
Hope this helped you and thanks for choosing FixYa.
Sep 09, 2011 | Danby DDR4588EE Dehumidifier
E1 CODE ERROR
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 30, 2009 | Danby DDR451 Dehumidifier
My DANBY Dehumidifier model DDR4588EE has been working ok until it showed a E1 error code and since then it does not work properly. Any ideas please?
Dec 30, 2009 | Dehumidifiers
Delonghi dh400p dehumidifier error e1 with ice
was the filter dirty that will do it let it defrost and put it back on
May 17, 2009 | DeLonghi De'Longhi Energy Star174;...
Kenmore model # 25800-25801 Error code E1?
unit has a sealed system leak call sears for tech support 1-800-905-9505 it is under warranty
Apr 15, 2008 | Kenmore 53701 Dehumidifier
Delonghi Dehumidifier DE400P / DH400P says error Code E1
Hi.
It is simple and easy to fix. E1 code for sensor behind right side grill. Take right side grill out, unplug sensor from wire socker and plug back. It is solve problem sometimes. Unit MUST be unplugged from outlet.
If no help, you need new sensor .
Thank you.
Dimitry.
Nov 10, 2007 | Dehumidifiers
DeLonghi DE500P Dehumidifier Logo
63 people viewed this question
Top DeLonghi Dehumidifiers Experts
nm156
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
