SOURCE: My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
SOURCE: tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
SOURCE: muted my sharp le 810 and now i can't retrieve the sound
If you push the volume button on set does it show on screen?
My guess would be the sound may be turned down on the box or tv or maybe in the TV menu the speakers may be turned off.
Does not sound (pardon the pun) like a circuit repair but like an error.
Check all audio settings or options first in the set and then the box.
