Was functioning fine then abruptly stopped recognizing discs loaded in cartridge. T-00 signal comes on now when started.
SOURCE: CDs will not load
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
SOURCE: How do you reset a 6 disc cd changer in 1999 VW Beetle?
1st just try unplugging the changer overnight. also check and see if a cd may be inserted into the cd mech itself.
SOURCE: ej # 1 slot getting cd error not loading or playing
Try a new cartridge, they do warp over time. That would be "best case scenerio" worst case is the optic is shot/out of alignment, etc. There should be a reset button on the changer below the cartridge "(@)" small pen sized dimple that can be pushed w/a ball point pen to reset. How old is the unit? it's still in the current lineup. If it still doesn't work, call Alpine USA, give them the serial # if you don't have a receipt for it. They can tell you when it was manufactured to check for warranty status. Otherwise your looking at $100 - $150 repair. They would just swap out the transport. Best of luck!. Hope this helps!
SOURCE: Need to eject Alpine Renault 6CD changer cartidge- no power?
lok at the 8 pin plug the first pin from the left is the power wire and the round metal part of the plug is the ground
good luck
the last pin on the right is the ignition
